メインコンテンツにスキップ
Lenovo ThinkPad T460 Charging Port Replacement
必要な工具と部品
  1. Lenovo ThinkPad T460 Charging Port Replacement, External Battery: 手順 1、 3の画像 1 Lenovo ThinkPad T460 Charging Port Replacement, External Battery: 手順 1、 3の画像 2 Lenovo ThinkPad T460 Charging Port Replacement, External Battery: 手順 1、 3の画像 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Charging Port Replacement: 手順 2、 3の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 2、 3の画像 2 Lenovo ThinkPad T460 Charging Port Replacement: 手順 2、 3の画像 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Charging Port Replacement, Bottom Cover: 手順 3、 2の画像 1 Lenovo ThinkPad T460 Charging Port Replacement, Bottom Cover: 手順 3、 2の画像 2
    • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
  4. Lenovo ThinkPad T460 Charging Port Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad T460 Charging Port Replacement: 手順 4、 3の画像 3
    • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
    • Pry the lower left corner of the bottom cover up by a few millimeters.
    • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
    • You may hear some snapping noises as the clips are released.
  5. Lenovo ThinkPad T460 Charging Port Replacement: 手順 5、 2の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 5、 2の画像 2
    • Slide the spudger along the right and top sides of the bottom cover to release the clips.
    • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
  6. Lenovo ThinkPad T460 Charging Port Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 6、 2の画像 2
    • Use the spudger to pry the upper left corner up by a few millimeters.
    • Pry up the sections of the bottom cover with printed logos of the ports.
    • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
  7. Lenovo ThinkPad T460 Charging Port Replacement: 手順 7、 2の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 7、 2の画像 2
    • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
  8. Lenovo ThinkPad T460 Charging Port Replacement: 手順 8、 3の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 8、 3の画像 2 Lenovo ThinkPad T460 Charging Port Replacement: 手順 8、 3の画像 3
    • Use both hands to lift the bottom cover up and away from the laptop.
  9. Lenovo ThinkPad T460 Charging Port Replacement, Charging Port: 手順 9、 2の画像 1 Lenovo ThinkPad T460 Charging Port Replacement, Charging Port: 手順 9、 2の画像 2
    • Remove two 4.7 mm screws from the hinge in the upper right-hand corner using a Phillips #1 screwdriver.
  10. Lenovo ThinkPad T460 Charging Port Replacement: 手順 10、 3の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 10、 3の画像 2 Lenovo ThinkPad T460 Charging Port Replacement: 手順 10、 3の画像 3
    • Lift the bottom of the laptop up by a few inches to rotate the upper right hinge.
    • Place the bottom of the laptop back down.
  11. Lenovo ThinkPad T460 Charging Port Replacement: 手順 11、 2の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
  12. Lenovo ThinkPad T460 Charging Port Replacement: 手順 12、 3の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 12、 3の画像 2 Lenovo ThinkPad T460 Charging Port Replacement: 手順 12、 3の画像 3
    • Use your fingers to remove the black cable from its slots above the motherboard.
  13. Lenovo ThinkPad T460 Charging Port Replacement: 手順 13、 2の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 13、 2の画像 2
    • Use your fingers to lift the gray cable out of its slots.
  14. Lenovo ThinkPad T460 Charging Port Replacement: 手順 14、 1の画像 1
    • Remove the single 4.7 mm screw from the charging port bracket using a Phillips #1 screwdriver.
  15. Lenovo ThinkPad T460 Charging Port Replacement: 手順 15、 2の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 15、 2の画像 2
    • Use your fingers to remove the charging port bracket from the laptop.
  16. Lenovo ThinkPad T460 Charging Port Replacement: 手順 16、 3の画像 1 Lenovo ThinkPad T460 Charging Port Replacement: 手順 16、 3の画像 2 Lenovo ThinkPad T460 Charging Port Replacement: 手順 16、 3の画像 3
    • Use your fingers to slide the charging port out from beneath the gray cable to remove it from the laptop.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
82,407 ポイント
200のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,392のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 33
過去 30 日: 141
今までの合計 4,052
