メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo ThinkPad P50 Keyboard Replacement
必要な工具と部品
  1. Lenovo ThinkPad P50 Keyboard Replacement, Battery: 手順 1、 2の画像 1 Lenovo ThinkPad P50 Keyboard Replacement, Battery: 手順 1、 2の画像 2
    • Slide the battery latch to the left to unlock it and remove the battery.
    FixBotに聞いてみる
  2. Lenovo ThinkPad P50 Keyboard Replacement, Bottom case screws: 手順 2、 1の画像 1
    • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
    • The screws will not come all the way out; do not attempt to remove them from the case.
    • Pull up the notch with your fingernail or a spudger.
    FixBotに聞いてみる
  3. Lenovo ThinkPad P50 Keyboard Replacement, Bottom case: 手順 3、 2の画像 1 Lenovo ThinkPad P50 Keyboard Replacement, Bottom case: 手順 3、 2の画像 2
    • Lift the lower case up and off of the chassis.
    FixBotに聞いてみる
  4. Lenovo ThinkPad P50 Keyboard Replacement, Trackpad: 手順 4、 2の画像 1 Lenovo ThinkPad P50 Keyboard Replacement, Trackpad: 手順 4、 2の画像 2
    • Remove the following screws with a Phillips #00 screwdriver:
    • Seven 5.7 mm screws
    • Five 4.3 mm screws
    • Three 12.6 mm screws
    FixBotに聞いてみる
  5. Lenovo ThinkPad P50 Keyboard Replacement: 手順 5、 2の画像 1 Lenovo ThinkPad P50 Keyboard Replacement: 手順 5、 2の画像 2
    • Turn the computer over and open the lid.
    • Insert an opening pick in the seam between the keyboard bezel and chassis.
    • Pry around the entire perimeter until the keyboard assembly fully releases.
    FixBotに聞いてみる
  6. Lenovo ThinkPad P50 Keyboard Replacement: 手順 6、 3の画像 1 Lenovo ThinkPad P50 Keyboard Replacement: 手順 6、 3の画像 2 Lenovo ThinkPad P50 Keyboard Replacement: 手順 6、 3の画像 3
    • Pivot the keyboard further up until you can see the connectors on the underside of the keyboard
    • Detach the connectors that connect to the trackpad.
    • Most of the time, these connectors will have a lip or a tab along the top that can be used to push the connector out of its socket.
    • To disconnect, use the wide end of a spudger to push on the connector tab to slide it out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    FixBotに聞いてみる
  7. Lenovo ThinkPad P50 Keyboard Replacement, Keyboard: 手順 7、 2の画像 1 Lenovo ThinkPad P50 Keyboard Replacement, Keyboard: 手順 7、 2の画像 2
    • Lift the keyboard slightly until you see the cable connection the keyboard to the rest of the computer
    FixBotに聞いてみる
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
作成者
2人の作成者と共同で作成されました。
Sara Richardson
メンバー登録日: 03/21/25
609 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 3-1, Botvin Spring 2025 UMass Dartmouth, Team 3-1, Botvin Spring 2025人のメンバー
UMASSD-BOTVIN-S25S3G1
3 メンバー
5のガイドは作成済み
1件のガイドコメント
This guide is woefully incorrect. You do not need to remove the palm rest in order to replace the keyboard. This is a great way to end up with a cracked palm rest if you're not careful. Please refer to the manufacturer's support guide here: Page 68 has the relevant material.
Shane Welsh - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 91
今までの合計 638
