メインコンテンツにスキップ
Lenovo ThinkPad P1 Gen 7 Base Cover Replacement
必要な工具と部品
  1. Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Turn off your laptop: 手順 1、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Turn off your laptop: 手順 1、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Turn off your laptop: 手順 1、 3の画像 3
    • Shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Loosen the base cover screws: 手順 2、 1の画像 1
    • Use a Phillips screwdriver to loosen the six captive screws securing the base cover.
  3. Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Loosen the base cover's left side: 手順 3、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Loosen the base cover's left side: 手順 3、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Loosen the base cover's left side: 手順 3、 3の画像 3
    • Press the tip of an opening pick into the seam between the base cover and the bottom-left corner of the frame (near the screen hinge).
    • It can be tricky to get the pick into the seam for the first time. Angle the pick vertically and press down with firm pressure.
    • Pivot the pick down and slide it around the corner to release the clips.
  4. Lenovo ThinkPad P1 Gen 7 Base Cover Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement: 手順 4、 3の画像 3
    • Slide the opening pick along the left edge to release the clips securing the cover.
  5. Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Loosen the base cover's right side: 手順 5、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Loosen the base cover's right side: 手順 5、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Loosen the base cover's right side: 手順 5、 3の画像 3
    • Press the tip of an opening pick into the seam between the base cover and the bottom-right corner of the frame (near the screen hinge).
  6. Lenovo ThinkPad P1 Gen 7 Base Cover Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement: 手順 6、 2の画像 2
    • Slide the opening pick along the right edge to release the clips securing the cover.
  7. Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Remove the base cover: 手順 7、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement, Remove the base cover: 手順 7、 2の画像 2
    • Grasp the base cover along the screen hinge edge and pull up to loosen the cover.
  8. Lenovo ThinkPad P1 Gen 7 Base Cover Replacement: 手順 8、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Base Cover Replacement: 手順 8、 2の画像 2
    • Lift and remove the base cover.
終わりに
作成者
5人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
283,244 ポイント
587のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,619のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 39
今までの合計 599
