メインコンテンツにスキップ
Lenovo Ideapad 320-17IKB Touchpad Replacement
必要な工具と部品
  1. Lenovo Ideapad 320-17IKB Touchpad Replacement, Back Panel: 手順 1、 1の画像 1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 2、 2の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 2、 2の画像 2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 3、 1の画像 1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 4、 2の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 4、 2の画像 2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Touchpad Replacement, Battery: 手順 5、 2の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement, Battery: 手順 5、 2の画像 2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 6、 2の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 6、 2の画像 2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Touchpad Replacement, Fan: 手順 7、 2の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement, Fan: 手順 7、 2の画像 2
    • Remove five 7mm Phillips #00 screws from the cooling fan.
  8. Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 8、 3の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 8、 3の画像 2 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 8、 3の画像 3
    • Gently lift the fan assembly out of the laptop.
    • Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
  9. Lenovo Ideapad 320-17IKB Touchpad Replacement, Heat Sink: 手順 9、 3の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement, Heat Sink: 手順 9、 3の画像 2 Lenovo Ideapad 320-17IKB Touchpad Replacement, Heat Sink: 手順 9、 3の画像 3
    • Gently lift and remove the heat sink and set it aside.
  10. Lenovo Ideapad 320-17IKB Touchpad Replacement, Wi-Fi Card: 手順 10、 3の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement, Wi-Fi Card: 手順 10、 3の画像 2 Lenovo Ideapad 320-17IKB Touchpad Replacement, Wi-Fi Card: 手順 10、 3の画像 3
    • Remove the single 3mm Phillips #0 screw from the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the laptop.
  11. Lenovo Ideapad 320-17IKB Touchpad Replacement, Motherboard: 手順 11、 3の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement, Motherboard: 手順 11、 3の画像 2 Lenovo Ideapad 320-17IKB Touchpad Replacement, Motherboard: 手順 11、 3の画像 3
    この手順で使用する道具:
    購入する
    • Gently pull the blue ribbon marked with "MB" connectors.
    • Gently remove the other connectors in the picture by pulling them straight out.
    • Blue connectors encased in a black holder may require tweezers to unclasp the connector for removal.
  12. Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 12、 3の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 12、 3の画像 2 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 12、 3の画像 3
    • Using a Jimmy, gently pry the motherboard from under the corner screw holder with one hand and pull the motherboard out with the other.
  13. Lenovo Ideapad 320-17IKB Touchpad Replacement, Touchpad: 手順 13、 2の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement, Touchpad: 手順 13、 2の画像 2
    • Use a Jimmy or opening tool to pry and and release the clips that secure the touchpad cover.
    • Soldering/glue is required to reattach this part.
    • Remove the touchpad cover.
  14. Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 14、 2の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 14、 2の画像 2
    • Use a Phillips #0 screwdriver to remove two 2.42 mm screws from the top of the touchpad.
    • Peel off the ribbon cable from the touchpad, which is attached with adhesive.
  15. Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 15、 3の画像 1 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 15、 3の画像 2 Lenovo Ideapad 320-17IKB Touchpad Replacement: 手順 15、 3の画像 3
    • Lift the touchpad from the bottom to remove it.
    • When you've replaced your touchpad, remember to reattach the ribbon cable as it will not function without it.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
作成者
1人の作成者と共同作成されました。
David Rojas
メンバー登録日: 02/08/24
97 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-3, Coppersmith Spring 2024 University of North Texas, Team 1-3, Coppersmith Spring 2024人のメンバー
UNT-COPPERSMITH-S24S1G3
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 5
過去 30 日: 16
今までの合計 43
