はじめに
Use this guide to replace and access a faulty port in your Lenovo IdeaPad 320-17IKB.
The several different ports that this laptop has allows the user to access and connect to other external devices or charge other devices; such as HDMI ports, power connector port, Ethernet port, SD port, CD port, USB ports, and the headphone jack.
If you aren’t able to connect to a port or if the port needs to be cleaned, you may need to consider cleaning or replacing the port. Follow the instructions in this guide to access the component.
Before using this guide, check out the Lenovo IdeaPad 320-17IKB Troubleshooting. Be cautious when lifting the back panel off the laptop to not damage any hardware.
Be sure to back up your hard drive before opening your laptop so that you don’t lose any data while you’re doing the replacement. Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
必要な工具と部品
Remove the single 3mm Phillips #0 screw from the Wi-Fi card.
Pull the Wi-Fi card straight out of the laptop.
Locate the terminals that need to be removed.
Clean the terminals with isopropyl alcohol and an old tooth brush.
ある他の人がこのガイドを完成しました。
