はじめに
This guide is about replacing the motherboard of the Lenovo IdeaPad 320-17IKB.
The motherboard is a printed circuit board and foundation of a computer that allocates power and allows communication between the CPU, RAM, and all other computer hardware components. The motherboard is the most important component of the computer. An outdated or damaged motherboard negatively affects the performance of the computer and sometimes has to be replaced.
Before using this guide, check out the Lenovo IdeaPad 320-17IKB Troubleshooting. Sometimes, the damaged back panel is the reason of disrupting the motherboard and other hardware. As a result, the motherboard does not have to be replaced in that case.
Be cautious when lifting the back panel off the laptop to not damage any hardware.
必要な工具と部品
Remove the single 3mm Phillips #0 screw from the Wi-Fi card.
Pull the Wi-Fi card straight out of the laptop.
3 の人々がこのガイドを完成させました。
