メインコンテンツにスキップ
Lenovo IdeaPad Flex 4-1470 Battery Replacement
必要な工具と部品
  1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Lower Case: 手順 1、 1の画像 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Battery Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Battery Replacement: 手順 2、 2の画像 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: 手順 3、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: 手順 3、 2の画像 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Battery Replacement: 手順 4、 1の画像 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Battery Replacement: 手順 5、 1の画像 1
    • Lift the battery up and out of the laptop.
終わりに
9 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Demario Robinson
メンバー登録日: 10/02/17
1,038 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S1G6
3 メンバー
10のガイドは作成済み
2 件のコメント
thank for sharing this! I want to check if it is easy to swap HDD/SSD?
pama - 返信
I'm grateful for the individuals who take time to share their knowledge. I'm 63yrs young with no technical skills. I followed your step by step instructions and was successful in changing my laptop battery. THANK YOU! 👩‍🦳👍
iamelara - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 29
今までの合計 13,939
