メインコンテンツにスキップ
Lenovo IdeaPad 130-15AST Cooling Fan Replacement
必要な工具と部品
  1. Lenovo IdeaPad 130-15AST Cooling Fan Replacement, DVD/CD Optical Drive: 手順 1、 1の画像 1
    • Verify that the DVD/CD Tray is free of DVD's and CD's.
    • Using a Phillips #00 screwdriver, remove one of the 6.0mm screws.
  2. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 2、 2の画像 2
    • Using the Jimmy Tool, gently pry the DVD/CD Drive away from the case of the laptop.
  3. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 3、 1の画像 1
    • Gently slide the DVD/CD Drive out of the laptop.
  4. Lenovo IdeaPad 130-15AST Cooling Fan Replacement, Cooling Fan: 手順 4、 1の画像 1
    • Before you proceed, make sure your computer is turned off and it is not connected to any power source.
    • Using a Phillips #1 screwdriver, remove 12 6mm screws.
  5. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 5、 3の画像 1 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 5、 3の画像 2 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 5、 3の画像 3
    • Do not try to completely remove this case without ensuring the entire case is free of connection points as this could crack or damage the case.
    • Use a thin, flat edge to gently break the seal of the case.
  6. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 6、 2の画像 1 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 6、 2の画像 2
    • Make sure that the back panel is completely free from the laptop.
    • Grab the sides of the back panel of the laptop with two hands. Then separate the panel from the laptop by lifting up. Place the panel aside from the laptop.
  7. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 7、 2の画像 1 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 7、 2の画像 2
    • Gently move the wires wrapped around the fan that run along the left side of the cooling fan.
    • These wires are not connected directly to the fan and should not be removed but simply displaced from their original location.
  8. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 8、 1の画像 1
    • Using the Phillips #0 screwdriver, to remove two 4.00mm screws.
    • You will need to save these screws, as a replacement cooling fan does not come with extra screws.
  9. Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 9、 3の画像 1 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 9、 3の画像 2 Lenovo IdeaPad 130-15AST Cooling Fan Replacement: 手順 9、 3の画像 3
    • Gently use a prying tool to disconnect the cooling fan from the motherboard.
    • After disconnecting the cooling fan, remove the fan from the laptop.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Trever Resheske
メンバー登録日: 09/22/19
768 ポイント
3のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 23
今までの合計 690
