この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください。
はじめに
この修理ガイドでLenovo IdeaPad 110-15IBRのバッテリーを交換します。裏側を取り出して、バッテリーのネジを外して、デバイスからバッターを外す作業が含まれます。
必要な工具と部品
マザーボードからバッテリーのケーブルコネクタの接続を外します。
デバイスからバッテリーを取り出します。
デバイスを再組立する際は、これらのインストラクションを逆の順番に従って作業を進めてください。
16 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
60%
翻訳を始める ›
23 件のコメント
Informative except , you didn’t mention the three screws underneath the DVD drive. The DVD drive must be removed first before you can remove the 3 additional screws.
I agree Clare! I didn’t see those either! Very frustrating at first! Thanks for the lead Clare!
Just cannot see where theres 13 screws got 11 cant see anything under or near the Drive clare.
Easy to follow
Thus the media in the laptop remains as it is?
brand new out of the box and it is frozen……..how can I get this returned
DO NOT try to remove the back without pulling the DVD drive and unscrewing the additional three screws!!! You'll break the thinnest part of the back. This guide erroneously makes no mention of these three flat screws.
Lenovo ideapad 110-15
(I am referring here to the model: Lenovo ideapad 110-15 ISK, model name: 80UD)
To Open the Laptop insides (Step 1)
To Remove the DVD Player (Steps 1 and 2)
To Remove the Battery (Steps 1 to 3)
To Remove the Hard drive (Steps 1 to 4)
Firstly, to Open the Laptop insides (Step 1)
1. Remove all the bottom screws (11 of them). Two of the eleven (in the middle) are for the keyboard, and the other one close to those in the middle, is for the DVD Player.
1a. Turn over the Laptop, so that the Keyboard faces you.
1b. Gently pry off the Keyboard. You can start from the top (small hooks) or from the bottom right (close to you) between the Key on the Keyboard marked [0 / INS] and [. / DEL] of the number keys. The 6 plastic hooks underneath, are situated at the edge of the Keyboard at the following keys: [. / DEL], [Down-arrow / PgDn], [Right-ALT], middle of [Space bar], left of {Space bar], and between [CTRL] and [FN].
1c. Gently tilt the Keyboard and turn it over towards you. ... (see next comment) ...
Peter Maas - 返信
(I am referring here to the model: Lenovo ideapad 110-15 ISK, Model name: 80UD)
To Open the Laptop insides (Step 1),
Remove DVD player (Steps 1 and 2),
Remove Battery (Steps 1 to 3),
Remove: Hard drive (Steps 1 to 4)
Firstly: To open the Laptop insides (Step 1)
Step 1. Remove all the bottom screws (11 of them). 2 of the 11 (in the middle opposite each other) are for the keyboard, and the other one close to those two in the middle, is for the DVD player .
a. Turn over the laptop and open it by lifting the screen panel, so that the keyboard faces you.
(See: next comment)
Peter Maas - 返信
Step 1c. Gently tilt the keyboard and turn it over towards you. Be careful – the connector cable is attached to the board underneath it.
d. Remove the screw to the right of the FAN (under the sticker) That one screw is holding the Bottom cover – 2 more screws to go if you need to loosen the Bottom cover!
e. Position the keyboard over its place, without putting it back in.
f. Turn over the laptop.
To remove DVD Player: (Steps 1 and 2)
Step 2. Slide the DVD player out and remove.
Continued in next comment)
(continued from previous comment. Be sure to follow Steps chronologically)
Step 1 c. Gently tilt the keyboard and turn it over towards you. Be careful – the connector cable is attached to the board underneath it.
(continued on next comment)
(continued from previous comment) To open the Laptop insides (Step 1)
ce Position the keyboard over its place, without putting it back in.
(continued in next comment)
Peter Maas - 返信
(continued from previous comments) Be sure to follow the steps chronologically...
To remove Bottom cover, and then Battery: (Steps 1 to 3)
Step 3. Remove the 2 screws under where the DVD player came out.
a. Turn over the laptop.
b. Gently pry off the bottom cover of the laptop, starting from above the hinges of the screen (=top part of laptop).
c. Remove the 2 remaining screws holding the battery in place.
d. Then gently turn over the bottom cover. You will see the battery connector cable attached to the main board.
e. Gently pull out the Connector cable at the point where it connects with the main board.
f. Remove the battery.
Peter Maas - 返信
(continued from previous comments) ... be sure to follow the Steps chronologically ...
To remove Hard drive (Steps 1-4):
Step 4. Remove the 6 screws holding the Hard drive.
a. Slide the Hard drive out.
That's it! I hope that helps.
Peter Maas - 返信
1. Remove all the bottom screws (11 of them). 2 of the 11 (in the middle) are for the keyboard, and the other one close to those two in the middle, is for the DVD player .
a. Turn over the laptop so that the keyboard faces you.
Peter Maas - 返信
I posted 4 different consecutive COMMENTS, but do not see them here!
Peter Maas - 返信
Contact me for the rest of the instructions
(continued from previous comment(s): be sure to follow the Steps chronologically)
To remove DVD Player: (do Steps 1 and 2)
(see next comment)
Peter Maas - 返信
Peter Maas - 返信
ifixit, where are the rest of the comments I posted? Please look at your Comments section on your website.
Peter Maas - 返信
Unter der tastatur noch eine zusäzliche schraube
Attention ! Sur le mien, il faut après avoir retiré la vis au dessus de l’étiquette blanche, faire coulisser le lecteur dvd vers l’extérieur (la vis le maintenait en place).
Une fois celui-ci retiré apparaissent les 3 dernières vis à retirer pour pouvoir retirer le boitier inférieur sans souci.
Dominique ENET - 返信
