はじめに
This guide will show how to replace the battery on the device. It walks through the process of removing the back, unscrewing the battery, and unplugging the batter from the device.
必要な工具と部品
Remove the thirteen 9 mm Phillips #1screws.
Pull out the DVD drive and unscrew the final 3 wide-head screws holding the back in place.
Gently pry the back off using a plastic opening tool, starting from one of the corners.
16 の人々がこのガイドを完成させました。
23 件のコメント
Informative except , you didn’t mention the three screws underneath the DVD drive. The DVD drive must be removed first before you can remove the 3 additional screws.
I agree Clare! I didn’t see those either! Very frustrating at first! Thanks for the lead Clare!
Just cannot see where theres 13 screws got 11 cant see anything under or near the Drive clare.
Easy to follow
