メインコンテンツにスキップ
Lenovo Edge 2-1580 Storage Replacement
必要な工具と部品
  1. Lenovo Edge 2-1580 Storage Replacement, Battery: 手順 1、 2の画像 1 Lenovo Edge 2-1580 Storage Replacement, Battery: 手順 1、 2の画像 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Storage Replacement: 手順 2、 2の画像 1 Lenovo Edge 2-1580 Storage Replacement: 手順 2、 2の画像 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Storage Replacement: 手順 3、 3の画像 1 Lenovo Edge 2-1580 Storage Replacement: 手順 3、 3の画像 2 Lenovo Edge 2-1580 Storage Replacement: 手順 3、 3の画像 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Storage Replacement: 手順 4、 1の画像 1
    • Pull the battery outward and remove it from the rest of the laptop.
    The removal of the hard drive isn’t completely necessary in order to access the hard drive for removal.
    seattlehudson - 返信
  5. Lenovo Edge 2-1580 Storage Replacement, Hard drive: 手順 5、 2の画像 1 Lenovo Edge 2-1580 Storage Replacement, Hard drive: 手順 5、 2の画像 2
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Storage Replacement: 手順 6、 2の画像 1 Lenovo Edge 2-1580 Storage Replacement: 手順 6、 2の画像 2
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
    The hard drive can also be slid backward from the connection. Then the clips will clear and can be easily lifted out. Additionally, it disconnects the hard drive at the same time. This also keeps from possibly breaking the clips or damaging the drive by prying.
    seattlehudson - 返信
  7. Lenovo Edge 2-1580 Storage Replacement: 手順 7、 2の画像 1 Lenovo Edge 2-1580 Storage Replacement: 手順 7、 2の画像 2
    • Carefully, using your hand, remove the hard drive from the laptop.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Julian Escallon
メンバー登録日: 09/27/17
714 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S14-G1, Boczar Fall 2017 USF Tampa, Team S14-G1, Boczar Fall 2017人のメンバー
USFT-BOCZAR-F17S14G1
4 メンバー
5のガイドは作成済み
3 件のコメント
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
randylovely - 返信
Thank you, was looking everywhere to find that out!!!
christopher busse -
Thank you, your help was so useful.
Alejandro E Jecke - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 4,197
