メインコンテンツにスキップ
Lenovo 500e Chromebook 2nd Gen Motherboard Replacement
必要な工具と部品
  1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 2、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 2、 2の画像 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 3、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 3、 2の画像 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Battery: 手順 4、 1の画像 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 5、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 5、 2の画像 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the three 4 mm screws (six total) from the left and right side brackets using a Phillips #00 screwdriver.
    • Gently remove the metal brackets from the motherboard.
  8. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 8、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 8、 2の画像 2
    • Remove the nine 4 mm screws from the motherboard using a Phillips #00 screwdriver.
  9. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 9、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 9、 2の画像 2
    • Gently remove the USB port from the side housing using an iFixit opening tool.
  10. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 10、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 10、 2の画像 2
    • Gently peel the metal strip away from the metal backing.
  11. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 11、 1の画像 1
    • Remove the single 3 mm screw that holds the Wi-Fi card in place using a Phillips #00 screwdriver.
  12. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 12、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 12、 2の画像 2
    • Disconnect the Wi-Fi card from the motherboard using an iFixit opening tool.
  13. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 13、 3の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 13、 3の画像 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 13、 3の画像 3
    • Using an iFixit opening tool, disconnect the camera cable.
    • Potential for device damage: Be gentle while removing the wire.
  14. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 14、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 14、 2の画像 2
    • Using an iFixit opening tool, detach the speaker wiring from the motherboard.
    • Set speakers aside for reinstallation.
  15. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 15、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 15、 2の画像 2
    • Using an iFixit opening tool, detach the track pad connector from the motherboard.
    • Potential for device damage: Be gentle while detaching the connector.
  16. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 16、 3の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 16、 3の画像 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 16、 3の画像 3
    • Using an iFixit opening tool, detach the keyboard cable from the motherboard.
    • Potential for device damage: Be gentle when detaching the cable.
  17. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 17、 2の画像 1 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 17、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using tweezers, disconnect the black cable from the motherboard.
    • Potential for device damage: Be gentle while detaching the cable.
  18. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 手順 18、 1の画像 1
    • Gently remove the motherboard from the laptop.
終わりに
作成者
4人の作成者と共同で作成されました。
Nicolas Lidinsky
メンバー登録日: 01/09/22
701 ポイント
5のガイドは作成済み
チーム
Illinois Wesleyan University, Team 1-3, Bullock Spring 2022 Illinois Wesleyan University, Team 1-3, Bullock Spring 2022人のメンバー
IWU-BULLOCK-S22S1G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 40
今までの合計 823
