はじめに
In the event that you're having trouble with your LeapPad 2, this guide will teach viewers how to disassemble their LeapPad 2 and fix any problem from changing the batteries up to fixing the motherboard.
必要な工具と部品
Turn the tablet so the back is visible.
One at a time, remove the battery covers by sliding them towards the sides and away from the center of the device.
Use a Phillips #1 screwdriver to remove the following screws from the device:
Four 7.0mm Phillips screws
Three 6.0mm Phillips screws
Two 10.0mm Phillips screws
Use a small plastic opening tool to begin separating the colored front cover from the white rear cover of the device.
With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and begin pulling the pieces apart.
Once only the top edge remains connected, simultaneously pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces together.
Use a Phillips #1 screwdriver to remove two 5.5mm screws from the plastic speaker holder.
Locate the following:
Two negative battery terminals.
Two negative battery wire glue-points.
One terminal at a time, pinch the battery side of the terminal towards the wire side of the terminal with a finger or thumb, and pull upwards away from the front cover to release the terminal from the cover.
Screen assembly tab locations.
Slide the motherboard in the direction of the game cartridge slot until the motherboard is out from under the metal tabs on the screen assembly.
