メインコンテンツにスキップ
Laser X 88016 LED Lights Repair
必要な工具と部品
  1. Laser X 88016 LED Lights Repair, Laser X 88016 LED Lights Repair: 手順 1、 2の画像 1 Laser X 88016 LED Lights Repair, Laser X 88016 LED Lights Repair: 手順 1、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the one 9.6 mm screw from the bottom of the laser gun and pull off the battery cover.
    • Phillips #0 will be used for all subsequent screw extractions throughout this guide.
    • Remove the three AAA batteries.
  2. Laser X 88016 LED Lights Repair: 手順 2、 3の画像 1 Laser X 88016 LED Lights Repair: 手順 2、 3の画像 2 Laser X 88016 LED Lights Repair: 手順 2、 3の画像 3
    • Using the Phillips #0 screwdriver, remove the six 9.6 mm screws located on the back of the receiver to expose the circuit board.
  3. Laser X 88016 LED Lights Repair: 手順 3、 2の画像 1 Laser X 88016 LED Lights Repair: 手順 3、 2の画像 2
    • Remove the 9.6mm screw fixing the circuit board to the receivers front cover using the Phillips #0 screwdriver.
  4. Laser X 88016 LED Lights Repair: 手順 4、 1の画像 1
    • Identify the LED wires on the circuit board and determine where the wires have become disconnected or shorted.
  5. Laser X 88016 LED Lights Repair: 手順 5、 3の画像 1 Laser X 88016 LED Lights Repair: 手順 5、 3の画像 2 Laser X 88016 LED Lights Repair: 手順 5、 3の画像 3
    • The LED wires are labeled TX and TG.
    • Use a helping hand to hold circuit board steady for soldering.
    • Solder the disconnected wire to the circuit board (in this case, the white wire to the node labeled TX.
    • Caution: Never touch the element or tip of the soldering iron. They are very hot (about 400°C) and will burn. Always return the soldering iron to its stand when not in use.
  6. Laser X 88016 LED Lights Repair: 手順 6、 3の画像 1 Laser X 88016 LED Lights Repair: 手順 6、 3の画像 2 Laser X 88016 LED Lights Repair: 手順 6、 3の画像 3
    • Reattach the circuit board to the receiver's front plate.
    • Put the batteries back in the laser gun and test for LED lights functionality.
    • If a specific LED light still does not function, verify the solder is not making a connection with the adjacent nodes.
終わりに
作成者
1人の作成者と共同作成されました。
James Lewis
メンバー登録日: 09/15/20
133 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S2-G9, Willis Fall 2020 University of Memphis, Team S2-G9, Willis Fall 2020人のメンバー
UM-WILLIS-F20S2G9
1 メンバー
1のガイドは作成済み
コメント 1 件
Hi, Do you know the PN for SW1? that turn on and off the unit?
Thanks
Alon S. - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 39
今までの合計 2,659
