はじめに
Use this guide to replace the rotor position sensor in your LG WM3050CW Washing Machine.
The rotor position sensor is a Hall effect sensor that detects the primary motor's position, direction, and speed.
必要な工具と部品
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
Lift the rear panel upward to release its bottom clips.
Pull the rear panel away from the chassis to release the remaining clips.
Use an impact driver to remove the 17 mm nut securing the rotor.
Alternatively, you can use a wrench and a hammer to loosen the nut.
Pull the rotor straight off the stator and drive shaft splines to remove it.
Use a Phillips driver to remove the three 16.6 mm‑long screws securing the motor harness clamps.
Use a 10 mm socket wrench to remove the six 68 mm-long bolts securing the stator.
Pull the stator off of the drum and flip it so its rear is facing upward.
Pull the rotor position sensor harness connector straight out of its socket to disconnect it.
Use your fingers to unclip the rotor position sensor from the stator.
Pull the sensor away from the stator to completely unclip it.
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
