メインコンテンツにスキップ
LG Vu CU920 Speaker Replacement
必要な工具と部品
  1. LG Vu CU920 Speaker Replacement, Battery: 手順 1、 3の画像 1 LG Vu CU920 Speaker Replacement, Battery: 手順 1、 3の画像 2 LG Vu CU920 Speaker Replacement, Battery: 手順 1、 3の画像 3
    • Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
  2. LG Vu CU920 Speaker Replacement: 手順 2、 2の画像 1 LG Vu CU920 Speaker Replacement: 手順 2、 2の画像 2
    • Remove the battery by placing your fingernail or an opening tool at the bottom edge of the battery and lift it out.
  3. LG Vu CU920 Speaker Replacement, Motherboard: 手順 3、 1の画像 1
    • Remove the two 3.5 mm screws above the battery port with a Phillips #00 screwdriver.
  4. LG Vu CU920 Speaker Replacement: 手順 4、 2の画像 1 LG Vu CU920 Speaker Replacement: 手順 4、 2の画像 2
    • Pull out the antenna to reveal a third screw.
    • Remove the 3.5 mm screw with a Phillips #00 screwdriver.
  5. LG Vu CU920 Speaker Replacement: 手順 5、 3の画像 1 LG Vu CU920 Speaker Replacement: 手順 5、 3の画像 2 LG Vu CU920 Speaker Replacement: 手順 5、 3の画像 3
    • Using a plastic opening tool, gently pop up the plastic tab.
    • Use the plastic opening tool to pry up the edges of the plastic casing. You will then be able to slide it around the edge to dislodge it.
  6. LG Vu CU920 Speaker Replacement: 手順 6、 2の画像 1 LG Vu CU920 Speaker Replacement: 手順 6、 2の画像 2
    • Remove the plastic case to reveal the motherboard.
  7. LG Vu CU920 Speaker Replacement: 手順 7、 1の画像 1
    • Use a spudger to disconnect the cables from the motherboard.
    • The following steps will detail how to detach the cables from the connectors.
  8. LG Vu CU920 Speaker Replacement: 手順 8、 3の画像 1 LG Vu CU920 Speaker Replacement: 手順 8、 3の画像 2 LG Vu CU920 Speaker Replacement: 手順 8、 3の画像 3
    • Gently lift the ZIF connector (black tab) holding the ribbon cable in place. When it is in the upright position, remove the cable from the back side.
  9. LG Vu CU920 Speaker Replacement: 手順 9、 1の画像 1
    • Remove the jack attached to the red and blue wires by carefully pulling it upward from the motherboard.
  10. LG Vu CU920 Speaker Replacement: 手順 10、 1の画像 1
    • Remove the round jack connected to the black cabel by carefully prying it up from beneath with a spudger or plastic opening tool.
    • This jack snaps on, so there will be more resistance than there was with the previous jack.
  11. LG Vu CU920 Speaker Replacement: 手順 11、 2の画像 1 LG Vu CU920 Speaker Replacement: 手順 11、 2の画像 2
    • Remove the remaining three ribbon cables by gently lifting them by the ends, opposite of the cables, with a plastic opening tool or spudger until they pop out.
  12. LG Vu CU920 Speaker Replacement: 手順 12、 3の画像 1 LG Vu CU920 Speaker Replacement: 手順 12、 3の画像 2 LG Vu CU920 Speaker Replacement: 手順 12、 3の画像 3
    • Remove the motherboard by gently prying it up with a spudger from the charging port.
    • Be careful not to yank the camera's ribbon cable as you lift the board. Make sure that it is in line with its hole in the motherboard.
    • Once the board has been lifted, remove it by pulling it away from the connected edge.
  13. LG Vu CU920 Speaker Replacement, Bezel and External Casing: 手順 13、 2の画像 1 LG Vu CU920 Speaker Replacement, Bezel and External Casing: 手順 13、 2の画像 2
    • Remove the 3.5mm screw holding the antenna guide in place with a Philips #00 screwdriver.
    • Slide the antenna out to the edge, and remove the plastic tubing by gently pulling it out from the opposite end of the antenna.
    • This step can be done after the motherboard is removed, or before (as photographed).
  14. LG Vu CU920 Speaker Replacement: 手順 14、 2の画像 1 LG Vu CU920 Speaker Replacement: 手順 14、 2の画像 2
    • Use a plastic opening tool to carefully pry up the metal antenna guide.
  15. LG Vu CU920 Speaker Replacement: 手順 15、 2の画像 1 LG Vu CU920 Speaker Replacement: 手順 15、 2の画像 2
    • Using a Philips #00 screwdriver, remove the two 3.5mm screws on the bottom corners of the device.
    • Remove the single 3.5mm screw located at the top next to the speaker's ribbon cable.
  16. LG Vu CU920 Speaker Replacement: 手順 16、 3の画像 1 LG Vu CU920 Speaker Replacement: 手順 16、 3の画像 2 LG Vu CU920 Speaker Replacement: 手順 16、 3の画像 3
    • Insert a plastic opening tool below the volume rocker and gently pry the silver casing up. As with the plastic casing over the motherboard, you should be able to slide the plastic opening tool along the edge to remove it.
  17. LG Vu CU920 Speaker Replacement, Speaker: 手順 17、 1の画像 1
    • Locate the speaker on the inside of the plastic casing.
    • Use a plastic opening tool to pry the speaker out. It is attached with an adhesive.
    • Install a replacement speaker in place of the old one.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Gregory Davis
メンバー登録日: 04/17/13
48 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 8-57, Johann Spring 2013 Cal Poly, Team 8-57, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S8G57
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 258
