この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The LCD screens are connected as one unit, and therefore should be removed together.
必要な工具と部品
Remove the two triangular pads at the top of the two speakers.
These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
Wedge the spudger into the small gap between the phone and the metal casing of the motherboard.
Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise.
Now use the spudger to lift the other side of the motherboard.
ある他の人がこのガイドを完成しました。
