この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The following guide will show the complete tear down of the phone in order to replace the internal phone casing.
必要な工具と部品
Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
Remove the battery using your finger to pry it out of the battery housing.
Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
3 の人々がこのガイドを完成させました。
