Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
Our device did not come with a battery cover so it is not shown here.
Remove the battery using your finger to pry it out of the battery housing.
この手順で使用する道具:
購入する
Carefully pry off the phone's backing using a plastic opening tool.
Slip the tool into the crack between the keypad (front panel) and the back panel.
Slide the tool along the sides of the phone to detach the tabs holding the backing on.
Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
この手順で使用する道具:
購入する
Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
The bottom two screws may have small rubber covers that you can remove using tweezers .
Pry off the front panel of the phone using a Plastic Opening Tool.
Push the tool into the crack along the side of the phone.
Slide the tool along the crack to detach the tabs holding the backing on the phone.
Remove the earpiece and gyroscope by lifting them out of the phone casing using tweezers.
The earpiece and gyroscope are adhered to the phone casing so it will take a small amount of force to remove them.
Be careful when removing these components as the connecting wires are easily broken/disconnected.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
