はじめに
If your audio quality is much worse than it used to be, you may need to replace your speaker system! The most common cause of poor speaker performance is because of water damage over time.
If your charger port is no longer working, it could be because of dirt clogged within the speaker. Try to clean the port and see if it works before replacing the entire port.
Before using this guide, make sure to review the LG V50 ThinQ troubleshooting page to ensure there are no other options to save your speakers or charging port.
If the speaker system or charger port needs to be replaced, this guide will help you replace them for your LG V50 ThinQ android phone. Make sure the device is powered off before replacing any parts.
必要な工具と部品
Flip the phone over, so that the back of the phone is facing you.
Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
