メインコンテンツにスキップ
LG V50 ThinQ Speaker & Charging Port Replacement
必要な工具と部品
  1. LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: 手順 1、 3の画像 1 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: 手順 1、 3の画像 2 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: 手順 1、 3の画像 3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Speaker & Charging Port Replacement: 手順 2、 3の画像 1 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 2、 3の画像 2 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 2、 3の画像 3
    • With the back side open, remove all 12 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Speaker & Charging Port Replacement: 手順 3、 3の画像 1 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 3、 3の画像 2 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 3、 3の画像 3
    • Remove the two brackets that are covering internal components.
  4. LG V50 ThinQ Speaker & Charging Port Replacement: 手順 4、 3の画像 1 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 4、 3の画像 2 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • Disconnect the battery from the phone by removing the battery connection from the connector port.
    • Disconnect the orange cable by pulling the connector up with your fingers.
    • Pull up with tweezers on the end of the white wire to disconnect it from the two circuit boards.
    • Pull up with tweezers on the dark orange cable to disconnect it.
  5. LG V50 ThinQ Speaker & Charging Port Replacement: 手順 5、 3の画像 1 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 5、 3の画像 2 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 5、 3の画像 3
    • Take out the SIM card by using the SIM head and pushing into the SIM ejector slot.
    • Disconnect the orange panel nearby the SIM slot from the circuit board.
    • Pull up from below the circuit board on the top, next to the CMOS battery to remove the upper circuiting from the phone.
  6. LG V50 ThinQ Speaker & Charging Port Replacement: 手順 6、 3の画像 1 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 6、 3の画像 2 LG V50 ThinQ Speaker & Charging Port Replacement: 手順 6、 3の画像 3
    • Pull up from the right of the metallic cover piece inside of the bottom right of the phone.
    • Remove the metallic piece's base from the board.
    • Make the cubic piece moveable by wiggling under it with an opening pick or spudger.
  7. LG V50 ThinQ Speaker & Charging Port Replacement: 手順 7、 1の画像 1
    • Remove bottom circuiting, the speaker system is a part of the bottom circuit board.
終わりに
作成者
3人の作成者と共同で作成されました。
William Martin
メンバー登録日: 11/01/23
231 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023人のメンバー
UMASSD-GULBRANDSEN-F23S2G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 191
