メインコンテンツにスキップ
LG Refrigerator Upper Ice Maker Assembly Replacement
必要な工具と部品
  1. LG Refrigerator Upper Ice Maker Assembly Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: 手順 2、 3の画像 1 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: 手順 2、 3の画像 2 LG Refrigerator Upper Ice Maker Assembly Replacement, Open the doors: 手順 2、 3の画像 3
    • Open both refrigerator doors fully.
  3. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: 手順 3、 2の画像 1 LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly screws: 手順 3、 2の画像 2
    • Use a #2 Philips driver to remove the screws that secure the ice maker assembly to the refrigerator door.
  4. LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 手順 4、 3の画像 1 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 手順 4、 3の画像 2 LG Refrigerator Upper Ice Maker Assembly Replacement, Reposition the ice maker assembly: 手順 4、 3の画像 3
    • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
    • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
  5. LG Refrigerator Upper Ice Maker Assembly Replacement: 手順 5、 3の画像 1 LG Refrigerator Upper Ice Maker Assembly Replacement: 手順 5、 3の画像 2 LG Refrigerator Upper Ice Maker Assembly Replacement: 手順 5、 3の画像 3
    • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
    • Squeeze the connector at the top of the ice maker assembly to release it.
    • Pull the connector straight down to disconnect it.
  6. LG Refrigerator Upper Ice Maker Assembly Replacement, Remove the ice maker assembly: 手順 6、 1の画像 1
    • Remove the ice maker assembly.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
作成者
2人の作成者と共同で作成されました。
Bill Gilbert
メンバー登録日: 06/30/22
38,497 ポイント
261のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,608のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 30
今までの合計 1,000
