はじめに
Use this guide to replace the ice and water dispenser on your LG refrigerator.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The ice and water dispenser dispenses ice and water through the left refrigerator door. It has paddles that operate switches located in the dispenser, which control the output of ice and water from the dispenser.
The ice and water dispenser has a number of components that may need replacing, including the display PC board, the ice and water dispensing switches, and sub-control PC board.
If the ice and water dispenser fails, you will notice erratic operation of the ice and water dispensing functions. They may also completely cease operation.
必要な工具と部品
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
To remove the left door handle, first open the right door.
Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
Right side clips
Top clips
Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
Use a spudger to pry out the top edge of the dispenser assembly.
Once you've created a gap, use your fingertips to pull the edge downward.
Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
Grasp the top edge of the dispenser assembly in the middle and pull outwards.
Continue prying and pulling around the perimeter of the assembly to release it.
Squeeze the multiple wire connectors and pull them straight off to disconnect them from the various PC boards.
Some of the connectors may be permanently attached to the PC board and can't be removed.
Use a Phillips screwdriver to remove the screw securing the circuit board holder to the dispenser assembly. Many, but not all, units will have this PC board and holder.
Lift and remove the circuit board holder from the dispenser assembly.
