メインコンテンツにスキップ
LG Refrigerator Freezer Thermistor Test and Replacement
必要な工具と部品
  1. LG Refrigerator Freezer Thermistor Test and Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Freezer Thermistor Test and Replacement, Open the freezer door: 手順 2、 2の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Open the freezer door: 手順 2、 2の画像 2
    • Pull open the freezer door fully.
  3. LG Refrigerator Freezer Thermistor Test and Replacement, Remove the drawer and bin: 手順 3、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Remove the drawer and bin: 手順 3、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement, Remove the drawer and bin: 手順 3、 3の画像 3
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator Freezer Thermistor Test and Replacement, Remove the drawer rail covers: 手順 4、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Remove the drawer rail covers: 手順 4、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement, Remove the drawer rail covers: 手順 4、 3の画像 3
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator Freezer Thermistor Test and Replacement, Reassembly notes: 手順 5、 2の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Reassembly notes: 手順 5、 2の画像 2
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator Freezer Thermistor Test and Replacement, Remove the drawer: 手順 6、 2の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Remove the drawer: 手順 6、 2の画像 2
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator Freezer Thermistor Test and Replacement: 手順 7、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 7、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 7、 3の画像 3
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator Freezer Thermistor Test and Replacement, Release the drawer slides: 手順 8、 1の画像 1
    • Use a Phillips screwdriver to remove the screws securing both left drawer slides.
  9. LG Refrigerator Freezer Thermistor Test and Replacement, Remove the upper left drawer slide: 手順 9、 2の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Remove the upper left drawer slide: 手順 9、 2の画像 2
    • Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
    • Remove the upper left drawer slide.
  10. LG Refrigerator Freezer Thermistor Test and Replacement, Release lower left drawer slide and reposition it: 手順 10、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Release lower left drawer slide and reposition it: 手順 10、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement, Release lower left drawer slide and reposition it: 手順 10、 3の画像 3
    • Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
    • Reposition the lower left drawer slide to gain access to the door switch connector.
  11. LG Refrigerator Freezer Thermistor Test and Replacement, Disconnect the drawer switch and remove the lower slide: 手順 11、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Disconnect the drawer switch and remove the lower slide: 手順 11、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement, Disconnect the drawer switch and remove the lower slide: 手順 11、 3の画像 3
    • Squeeze the door switch connector to release it.
    • Pull the door switch connector down to disconnect it.
    • Remove the lower left drawer slide.
    • If you are removing the freezer evaporator cover, likely only the left-hand slides may need to be removed. In some cases you will need to repeat the previous three steps to remove the right slides as well.
  12. LG Refrigerator Freezer Thermistor Test and Replacement, Release the ice maker: 手順 12、 1の画像 1
    • Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
  13. LG Refrigerator Freezer Thermistor Test and Replacement: 手順 13、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 13、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 13、 3の画像 3
    • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
    • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
    • When the tab releases, pull the right front corner of the ice maker down.
  14. LG Refrigerator Freezer Thermistor Test and Replacement: 手順 14、 1の画像 1
    • Repeat the previous operation on the left side of the ice maker to release it.
  15. LG Refrigerator Freezer Thermistor Test and Replacement: 手順 15、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 15、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 15、 3の画像 3
    • Grasp the front edge of the ice maker and pull it towards you.
    • Lower the ice maker.
  16. LG Refrigerator Freezer Thermistor Test and Replacement, Disconnect and remove the ice maker: 手順 16、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Disconnect and remove the ice maker: 手順 16、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement, Disconnect and remove the ice maker: 手順 16、 3の画像 3
    • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
    • Remove the ice maker.
  17. LG Refrigerator Freezer Thermistor Test and Replacement, Remove air return cover: 手順 17、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Remove air return cover: 手順 17、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement, Remove air return cover: 手順 17、 3の画像 3
    • Pinch the rear portion of the air return cover to release it from the freezer wall.
    • Pull the air return cover outward and remove it.
  18. LG Refrigerator Freezer Thermistor Test and Replacement, Unfasten the evaporator cover: 手順 18、 1の画像 1
    • Use a Philips screwdriver to remove the screw (or screws) securing the evaporator cover.
  19. LG Refrigerator Freezer Thermistor Test and Replacement, Reposition the evaporator cover: 手順 19、 2の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Reposition the evaporator cover: 手順 19、 2の画像 2
    • Don't try to remove the evaporator cover fully, as It is still connected to the fridge with a number of wires.
    • Grasp the evaporator cover by the air vent openings and pull the top edge toward you.
  20. LG Refrigerator Freezer Thermistor Test and Replacement: 手順 20、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 20、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 20、 3の画像 3
    • Lift the evaporator cover slightly to release the tabs at the lower edge.
    • Swing the left edge of the evaporator cover toward you and lower it.
  21. LG Refrigerator Freezer Thermistor Test and Replacement, Disconnect the evaporator cover: 手順 21、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Disconnect the evaporator cover: 手順 21、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement, Disconnect the evaporator cover: 手順 21、 3の画像 3
    • Disconnect the electrical connections in the upper left corner of the freezer.
    • Make a note of the locations of the connections for re-installation.
  22. LG Refrigerator Freezer Thermistor Test and Replacement: 手順 22、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 22、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement: 手順 22、 3の画像 3
    • Swing the left edge of the evaporator cover further toward you to access the connections in the upper right corner.
    • Squeeze and pull the connector to disconnect the thermistor mounted in the evaporator cover.
  23. LG Refrigerator Freezer Thermistor Test and Replacement, Remove the evaporator cover: 手順 23、 2の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Remove the evaporator cover: 手順 23、 2の画像 2
    • Remove the evaporator cover.
  24. LG Refrigerator Freezer Thermistor Test and Replacement, Peel up the insulation: 手順 24、 2の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Peel up the insulation: 手順 24、 2の画像 2
    • On the rear of the evaporator cover, peel up the insulation pad covering the thermistor.
  25. LG Refrigerator Freezer Thermistor Test and Replacement, Remove the thermistor: 手順 25、 3の画像 1 LG Refrigerator Freezer Thermistor Test and Replacement, Remove the thermistor: 手順 25、 3の画像 2 LG Refrigerator Freezer Thermistor Test and Replacement, Remove the thermistor: 手順 25、 3の画像 3
    • Use a spudger to pry the thermistor out of its mounting clips.
    • Thread the thermistor through the slot in the insulation pad and remove it.
  26. LG Refrigerator Freezer Thermistor Test and Replacement, Test the thermistor: 手順 26、 1の画像 1
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
ある他の人がこのガイドを完成しました。
Bill Gilbert
メンバー登録日: 06/30/22
38,497 ポイント
261のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,608のガイドは作成済み
1件のガイドコメント
IMHO, LG needs an improved evaporator fan or thermistor. The fan might spin faster to push more cold freezer air into the warm refrigerator. The thermistor needs new software so the thermistor can report a warm refrigerator as not yet at the desired temperature (ie, the revised thermistor must report lower resistances). The refrigerators are beautiful. The compressors are adequate. The air flow is unacceptable to keep milk cold in the refrigerator compartment.
David Warlick - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 65
過去 30 日: 310
今までの合計 7,383
