メインコンテンツにスキップ
LG Refrigerator Display Board Replacement
必要な工具と部品
  1. LG Refrigerator Display Board Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Display Board Replacement, Loosen the left door handle set screws: 手順 2、 2の画像 1 LG Refrigerator Display Board Replacement, Loosen the left door handle set screws: 手順 2、 2の画像 2
    • To remove the left door handle, first open the right door.
    • Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
  3. LG Refrigerator Display Board Replacement, Remove the left door handle: 手順 3、 2の画像 1 LG Refrigerator Display Board Replacement, Remove the left door handle: 手順 3、 2の画像 2
    • Pull the left door handle straight off to remove it.
  4. LG Refrigerator Display Board Replacement, Retaining clip locations: 手順 4、 3の画像 1 LG Refrigerator Display Board Replacement, Retaining clip locations: 手順 4、 3の画像 2 LG Refrigerator Display Board Replacement, Retaining clip locations: 手順 4、 3の画像 3
    • The dispenser assembly is secured by very strong clips, making it very difficult to remove. Take note of the clip location examples shown in the photos:
    • Right side clips
    • Top clips
    • Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
    • During disassembly, you may break some of these clips. If you do, don't worry; the assembly does not need all the clips to be properly secured.
  5. LG Refrigerator Display Board Replacement, Release the dispenser: 手順 5、 3の画像 1 LG Refrigerator Display Board Replacement, Release the dispenser: 手順 5、 3の画像 2 LG Refrigerator Display Board Replacement, Release the dispenser: 手順 5、 3の画像 3
    • Use a spudger to pry out the top edge of the dispenser assembly.
    • Once you've created a gap, use your fingertips to pull the edge downward.
    • Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
    • Optionally, you may use a flat-blade screwdriver to assist in this process. Be careful not to damage the door; you may scratch the door surface or dent the rim of the dispenser opening.
  6. LG Refrigerator Display Board Replacement, Reposition the dispenser: 手順 6、 3の画像 1 LG Refrigerator Display Board Replacement, Reposition the dispenser: 手順 6、 3の画像 2 LG Refrigerator Display Board Replacement, Reposition the dispenser: 手順 6、 3の画像 3
    • Grasp the top edge of the dispenser assembly in the middle and pull outwards.
    • Continue prying and pulling around the perimeter of the assembly to release it.
  7. LG Refrigerator Display Board Replacement: 手順 7、 3の画像 1 LG Refrigerator Display Board Replacement: 手順 7、 3の画像 2 LG Refrigerator Display Board Replacement: 手順 7、 3の画像 3
    • Grasp the assembly firmly and pull it out of the refrigerator door.
    • Don't try to pull the assembly completely off the refrigerator door. The assembly is still connected with numerous wires. These are mainly connected to the left side of the dispenser.
  8. LG Refrigerator Display Board Replacement, Disconnect the dispenser: 手順 8、 1の画像 1
    • Squeeze the multiple wire connectors and pull them straight off to disconnect them from the various PC boards.
    • Some of the connectors may be permanently attached to the PC board and can't be removed.
  9. LG Refrigerator Display Board Replacement: 手順 9、 2の画像 1 LG Refrigerator Display Board Replacement: 手順 9、 2の画像 2
    • Squeeze and separate the various connectors in the wiring harness. The photo shows two examples.
  10. LG Refrigerator Display Board Replacement, Unfasten the circuit board holder: 手順 10、 3の画像 1 LG Refrigerator Display Board Replacement, Unfasten the circuit board holder: 手順 10、 3の画像 2 LG Refrigerator Display Board Replacement, Unfasten the circuit board holder: 手順 10、 3の画像 3
    • Use a Phillips screwdriver to remove the screw securing the circuit board holder to the dispenser assembly. Many, but not all, units will have this PC board and holder.
    • Lift and remove the circuit board holder from the dispenser assembly.
  11. LG Refrigerator Display Board Replacement, Remove the dispenser: 手順 11、 1の画像 1
    • You can now remove the dispenser from the refrigerator.
    • The circuit board holder, if present, can be suspended from the harness wires, as its weight is minimal.
  12. LG Refrigerator Display Board Replacement, Release the ice dispensing switch wires: 手順 12、 2の画像 1 LG Refrigerator Display Board Replacement, Release the ice dispensing switch wires: 手順 12、 2の画像 2
    • Remove the tape securing wires to the rear of the dispenser assembly.
  13. LG Refrigerator Display Board Replacement: 手順 13、 2の画像 1 LG Refrigerator Display Board Replacement: 手順 13、 2の画像 2
    • Remove the wires from the clip.
  14. LG Refrigerator Display Board Replacement, Disconnect the ice dispensing switch: 手順 14、 2の画像 1 LG Refrigerator Display Board Replacement, Disconnect the ice dispensing switch: 手順 14、 2の画像 2
    • Pull the connector from the ice dispensing switch to disconnect it.
  15. LG Refrigerator Display Board Replacement, Unfasten the display board: 手順 15、 1の画像 1
    • Use a Phillips driver to remove the screws securing the display board to the dispenser assembly.
  16. LG Refrigerator Display Board Replacement, Remove the display board: 手順 16、 3の画像 1 LG Refrigerator Display Board Replacement, Remove the display board: 手順 16、 3の画像 2 LG Refrigerator Display Board Replacement, Remove the display board: 手順 16、 3の画像 3
    • Lift the display board off and remove it.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
メンバー登録日: 06/30/22
38,497 ポイント
261のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,608のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 48
今までの合計 1,470
