メインコンテンツにスキップ
LG Refrigerator Condenser Fan Motor Replacement
必要な工具と部品
  1. LG Refrigerator Condenser Fan Motor Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Condenser Fan Motor Replacement, Unfasten the condenser cover: 手順 2、 1の画像 1
    • Use a Phillips screwdriver to remove the screws securing the condenser cover to the rear of the refrigerator.
  3. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser cover: 手順 3、 3の画像 1 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser cover: 手順 3、 3の画像 2 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser cover: 手順 3、 3の画像 3
    • Tilt the top edge of the condenser cover toward you.
    • Lift and remove the condenser cover.
  4. LG Refrigerator Condenser Fan Motor Replacement, Disconnect the condenser fan: 手順 4、 2の画像 1 LG Refrigerator Condenser Fan Motor Replacement, Disconnect the condenser fan: 手順 4、 2の画像 2
    • Squeeze and pull the condenser fan connector straight down to disconnect the condenser fan.
  5. LG Refrigerator Condenser Fan Motor Replacement, Unfasten the condenser fan shroud: 手順 5、 1の画像 1
    • Use a Phillips screwdriver to remove the condenser fan shroud screw.
  6. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: 手順 6、 3の画像 1 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: 手順 6、 3の画像 2 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan blade assembly: 手順 6、 3の画像 3
    • Place a pair of slip joint pliers around the condenser fan drive shaft.
    • Place a large flat blade screwdriver between the slip joint pliers and the fan hub.
    • While holding the pliers in place, push the screwdriver against the pliers to pry the fan off.
  7. LG Refrigerator Condenser Fan Motor Replacement: 手順 7、 2の画像 1 LG Refrigerator Condenser Fan Motor Replacement: 手順 7、 2の画像 2
    • Remove the fan blade assembly.
  8. LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan motor: 手順 8、 3の画像 1 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan motor: 手順 8、 3の画像 2 LG Refrigerator Condenser Fan Motor Replacement, Remove the condenser fan motor: 手順 8、 3の画像 3
    • Use a stubby Phillips screwdriver to remove the screws securing the fan motor inside the fan motor bracket.
    • You may find it easier to use a 1/4 inch drive socket with a Phillips head bit to remove the screws.
  9. LG Refrigerator Condenser Fan Motor Replacement, Remove the fan motor: 手順 9、 3の画像 1 LG Refrigerator Condenser Fan Motor Replacement, Remove the fan motor: 手順 9、 3の画像 2 LG Refrigerator Condenser Fan Motor Replacement, Remove the fan motor: 手順 9、 3の画像 3
    • Push apart the two halves of the fan motor bracket to release the fan motor.
    • Slide the fan motor shaft up through the slot in the front fan motor bracket.
  10. LG Refrigerator Condenser Fan Motor Replacement: 手順 10、 2の画像 1 LG Refrigerator Condenser Fan Motor Replacement: 手順 10、 2の画像 2
    • Remove the fan motor.
  11. LG Refrigerator Condenser Fan Motor Replacement, Transfer the motor mounting washers: 手順 11、 3の画像 1 LG Refrigerator Condenser Fan Motor Replacement, Transfer the motor mounting washers: 手順 11、 3の画像 2 LG Refrigerator Condenser Fan Motor Replacement, Transfer the motor mounting washers: 手順 11、 3の画像 3
    • Transfer the two rubber motor mounting washers from the old motor to the new motor.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
メンバー登録日: 06/30/22
30,188 ポイント
213のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,449のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 37
過去 30 日: 162
今までの合計 508
