メインコンテンツにスキップ
LG K30 Charging Port Replacement
必要な工具と部品
  1. LG K30 Charging Port Replacement, Battery: 手順 1、 2の画像 1 LG K30 Charging Port Replacement, Battery: 手順 1、 2の画像 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Charging Port Replacement: 手順 2、 1の画像 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Charging Port Replacement: 手順 3、 1の画像 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Charging Port Replacement: 手順 4、 1の画像 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Charging Port Replacement: 手順 5、 2の画像 1 LG K30 Charging Port Replacement: 手順 5、 2の画像 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Charging Port Replacement, Motherboard: 手順 6、 1の画像 1
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
  7. LG K30 Charging Port Replacement: 手順 7、 2の画像 1 LG K30 Charging Port Replacement: 手順 7、 2の画像 2
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
  8. LG K30 Charging Port Replacement, Charging Port: 手順 8、 3の画像 1 LG K30 Charging Port Replacement, Charging Port: 手順 8、 3の画像 2 LG K30 Charging Port Replacement, Charging Port: 手順 8、 3の画像 3
    • For a guide on how to solder and unsolder components; please refer to: How To Solder and Desolder Connections
    • Peel back gold plastic protective film on motherboard to reveal 4 solder points which need to be desoldered with the desoldering wick.
    • Use extreme caution: soldering iron can become extremely hot and cause burns.
  9. LG K30 Charging Port Replacement: 手順 9、 2の画像 1 LG K30 Charging Port Replacement: 手順 9、 2の画像 2
    • Flip the motherboard over to the backside and use soldering iron to melt the solder on the charging port terminals; use the desoldering wick to remove the solder.
終わりに
作成者
3人の作成者と共同で作成されました。
Alisha Lee
メンバー登録日: 09/19/19
277 ポイント
3のガイドは作成済み
チーム
University of North Alabama, Team S1-G1, Winner Fall 2019 University of North Alabama, Team S1-G1, Winner Fall 2019人のメンバー
UNA-WINNER-F19S1G1
4 メンバー
6のガイドは作成済み
コメント 1 件
Is the K30 the same inside as the K40?
Daisey Flowerr - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 2,199
