メインコンテンツにスキップ
LG G8 ThinQ Headphone Jack Replacement
必要な工具と部品
  1. LG G8 ThinQ Headphone Jack Replacement, SIM Card Tray: 手順 1、 3の画像 1 LG G8 ThinQ Headphone Jack Replacement, SIM Card Tray: 手順 1、 3の画像 2 LG G8 ThinQ Headphone Jack Replacement, SIM Card Tray: 手順 1、 3の画像 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Headphone Jack Replacement, Back Panel: 手順 2、 3の画像 1 LG G8 ThinQ Headphone Jack Replacement, Back Panel: 手順 2、 3の画像 2 LG G8 ThinQ Headphone Jack Replacement, Back Panel: 手順 2、 3の画像 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Headphone Jack Replacement, Midframe: 手順 3、 3の画像 1 LG G8 ThinQ Headphone Jack Replacement, Midframe: 手順 3、 3の画像 2 LG G8 ThinQ Headphone Jack Replacement, Midframe: 手順 3、 3の画像 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Headphone Jack Replacement, Speaker System: 手順 4、 3の画像 1 LG G8 ThinQ Headphone Jack Replacement, Speaker System: 手順 4、 3の画像 2 LG G8 ThinQ Headphone Jack Replacement, Speaker System: 手順 4、 3の画像 3
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Headphone Jack Replacement, Headphone Jack: 手順 5、 3の画像 1 LG G8 ThinQ Headphone Jack Replacement, Headphone Jack: 手順 5、 3の画像 2 LG G8 ThinQ Headphone Jack Replacement, Headphone Jack: 手順 5、 3の画像 3
    • Using an opening tool, carefully disconnect the ribbon cable connecting the 3.5mm audio jack to the motherboard.
    • Remove the screw holding the 3.5 mm audio jack in place using a Phillips #000 screwdriver.
    • Remove the audio jack from the phone.
終わりに
作成者
3人の作成者と共同で作成されました。
Hunter Johnson
メンバー登録日: 09/17/21
221 ポイント
2のガイドは作成済み
チーム
Western Carolina University, Team 1-4, Virtue Fall 2021 Western Carolina University, Team 1-4, Virtue Fall 2021人のメンバー
WCU-VIRTUE-F21S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 18
今までの合計 847
