はじめに
Use this guide to replace the charge port on a LG G6. If you're having charging issues or your microphone isn't working, replacing the charge port is a good place to start.
必要な工具と部品
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
In the following steps you will be cutting through the adhesive on the rear glass panel.
Take note of the following areas:
In addition to cutting around the edge, there is extra adhesive here that should be cut.
Avoid sticking the spudger blade in too far here, to avoid damaging the rear button ribbon cable and chip.
Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can.
Lift on the suction cup, and insert a halberd spudger or opening pick under the rear glass.
Use the opening picks to slice through any remaining adhesive and open the phone.
Remove the glass from the phone.
Separate the rear glass from the phone,
Remove eleven Philips #00 screws.
Use the flat end of a spudger to disconnect the LCD/Digitizer flex cable.
Use the flat end of a spudger to disconnect the charge port flex cable.
Insert a SIM card opening tool into the small hole on the left side of the phone and remove the SIM card tray.
Use the flat end of a spudger to remove the adhesive securing the USB-C charge port to the frame.
12 の人々がこのガイドを完成させました。
4 件のコメント
Excellent AAAAAAAAA ++++
Awesome tutorial, I skipped the from step 11 to 15. No need to remove the button assembly. Just skipped that and reused the back glass panel with no problems. Thank you!
I can’t get the back off. I’ve tried so hard but it wont come off. I pulled so &&^&^$^ hard i cracked the back but couldnt get the &&^&^$^ back off wtf
Hi , I have replaced the port but usb comm still not working. QC3 not working because it also works with working usb comm. I have tried many original cords and chargers.
