メインコンテンツにスキップ
LG G3 Loudspeaker Replacement
必要な工具と部品
  1. LG G3 Loudspeaker Replacement, Back Cover: 手順 1、 2の画像 1 LG G3 Loudspeaker Replacement, Back Cover: 手順 1、 2の画像 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Loudspeaker Replacement: 手順 2、 2の画像 1 LG G3 Loudspeaker Replacement: 手順 2、 2の画像 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Loudspeaker Replacement, Battery: 手順 3、 2の画像 1 LG G3 Loudspeaker Replacement, Battery: 手順 3、 2の画像 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Loudspeaker Replacement: 手順 4、 2の画像 1 LG G3 Loudspeaker Replacement: 手順 4、 2の画像 2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Loudspeaker Replacement, Loudspeaker: 手順 5、 1の画像 1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Loudspeaker Replacement: 手順 6、 2の画像 1 LG G3 Loudspeaker Replacement: 手順 6、 2の画像 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Loudspeaker Replacement: 手順 7、 3の画像 1 LG G3 Loudspeaker Replacement: 手順 7、 3の画像 2 LG G3 Loudspeaker Replacement: 手順 7、 3の画像 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
終わりに
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
8 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
203,353 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 14,192
