メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG G Watch Display Assembly Replacement
必要な工具と部品
  1. LG G Watch Display Assembly Replacement, Wristband: 手順 1、 1の画像 1
    この手順で使用する道具:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
    FixBotに聞いてみる
    コメントを追加
  2. LG G Watch Display Assembly Replacement: 手順 2、 2の画像 1 LG G Watch Display Assembly Replacement: 手順 2、 2の画像 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
    FixBotに聞いてみる
    コメントを追加
  3. LG G Watch Display Assembly Replacement, Rear Case: 手順 3、 1の画像 1
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
    FixBotに聞いてみる
    コメントを追加
  4. LG G Watch Display Assembly Replacement: 手順 4、 2の画像 1 LG G Watch Display Assembly Replacement: 手順 4、 2の画像 2
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
    FixBotに聞いてみる
    コメントを追加
  5. LG G Watch Display Assembly Replacement, Gasket: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
    FixBotに聞いてみる
    コメントを追加
  6. LG G Watch Display Assembly Replacement, Motherboard: 手順 6、 2の画像 1 LG G Watch Display Assembly Replacement, Motherboard: 手順 6、 2の画像 2
    • Use the spudger to gently lift up and disconnect the display connector.
    • Now use the spudger to disconnect the digitizer connector.
    FixBotに聞いてみる
    コメントを追加
  7. LG G Watch Display Assembly Replacement: 手順 7、 2の画像 1 LG G Watch Display Assembly Replacement: 手順 7、 2の画像 2
    • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
    • Use the spudger to gently remove the motherboard.
    FixBotに聞いてみる
    コメントを追加
  8. LG G Watch Display Assembly Replacement, Removing the screen: 手順 8、 1の画像 1
    • Apply a small amount of pressure to the back of the LCD to create a gap for the opening pick.
    • Gently work the pick around the perimeter of the device to loosen up the adhesive.
    • An iOpener may be necessary to help loosen up the adhesive. Refer to our iOpener guide for info on how to use it.
    FixBotに聞いてみる
    コメントを追加
  9. LG G Watch Display Assembly Replacement: 手順 9、 2の画像 1 LG G Watch Display Assembly Replacement: 手順 9、 2の画像 2
    • After using the pick to loosen the adhesive, simply pull the display assembly up from the metal bezel.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Mandy McGarry
メンバー登録日: 09/23/14
165 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 2-5, Blackwell Fall 2014 USF Tampa, Team 2-5, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S2G5
5 メンバー
9のガイドは作成済み
4件のガイドコメント
Where can you purchase replacement parts?
Brian Winebarger - 返信 共有
Someone knows where to find a screen replacement?, i found at alibaba but i have to buy 1k ... :(
George Momo Seyssel - 返信 共有
I found a 00 screwdriver was better than 000 for removing the motherboard.
Peter Jeremy - 返信 共有
Be smart buy a used one for nuthin on eBay….
jeromedaues - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 42
今までの合計 5,004
