With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Insert a plastic opening tool in the small crevasse between the screen and the back panel.
Pry the screen away from the back panel.
Repeat this on each edge of the device.
We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
After using the plastic opening tools, pry the device open with your hands.
Remove the back panel from the screen.
この手順で使用する道具:
Magnetic Project Mat
$19.95
購入する
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
