メインコンテンツにスキップ
LG G Pad 8.3 Rear Facing Camera Replacement
必要な工具と部品
  1. LG G Pad 8.3 Rear Facing Camera Replacement, Back Panel: 手順 1、 2の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement, Back Panel: 手順 1、 2の画像 2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Rear Facing Camera Replacement: 手順 2、 3の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement: 手順 2、 3の画像 2 LG G Pad 8.3 Rear Facing Camera Replacement: 手順 2、 3の画像 3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Rear Facing Camera Replacement: 手順 3、 2の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement: 手順 3、 2の画像 2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Rear Facing Camera Replacement, Speaker: 手順 4、 2の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement, Speaker: 手順 4、 2の画像 2
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  5. LG G Pad 8.3 Rear Facing Camera Replacement: 手順 5、 1の画像 1
    • Use your fingers to remove the speaker.
  6. LG G Pad 8.3 Rear Facing Camera Replacement, Battery: 手順 6、 2の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement, Battery: 手順 6、 2の画像 2
    • Remove the 3mm Phillips #000 screws from the corners of the battery.
  7. LG G Pad 8.3 Rear Facing Camera Replacement: 手順 7、 3の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement: 手順 7、 3の画像 2 LG G Pad 8.3 Rear Facing Camera Replacement: 手順 7、 3の画像 3
    • Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
    • The cable is attached with an adhesive.
    • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
  8. LG G Pad 8.3 Rear Facing Camera Replacement: 手順 8、 2の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement: 手順 8、 2の画像 2
    • Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
    • Remove the ribbon cable from the device.
  9. LG G Pad 8.3 Rear Facing Camera Replacement: 手順 9、 2の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement: 手順 9、 2の画像 2
    • Unhook the battery from the top of the device.
  10. LG G Pad 8.3 Rear Facing Camera Replacement, Motherboard: 手順 10、 1の画像 1
    • Unhook the small yellow ribbon on top of the motherboard.
  11. LG G Pad 8.3 Rear Facing Camera Replacement: 手順 11、 1の画像 1
    • Remove all the 3mm silver screws and the 2mm black screws on the motherboard and carefully lift it out of the device.
  12. LG G Pad 8.3 Rear Facing Camera Replacement: 手順 12、 2の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement: 手順 12、 2の画像 2
    • Use a plastic opening tool to lift the motherboard out of the device.
  13. LG G Pad 8.3 Rear Facing Camera Replacement, Rear Facing Camera: 手順 13、 2の画像 1 LG G Pad 8.3 Rear Facing Camera Replacement, Rear Facing Camera: 手順 13、 2の画像 2
    • Use a plastic opening tool to remove the camera, which is attached with adhesive to the front of the tablet.
終わりに
作成者
4人の作成者と共同で作成されました。
Mario Salguero
メンバー登録日: 09/14/15
781 ポイント
6のガイドは作成済み
チーム
CSU Fullerton, Team 1-6, Bruce Fall 2015 CSU Fullerton, Team 1-6, Bruce Fall 2015人のメンバー
CSUF-BRUCE-F15S1G6
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 589
