はじめに
If your tablet isn't working properly, you may need to replace the motherboard. This guide will show you how to replace the motherboard.
必要な工具と部品
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
もう少しです!
終わりに
8 の人々がこのガイドを完成させました。
