はじめに
Replacing the motherboard of a phone can seem like a daunting task. But with the right tools and patience, you can repair this device. In this guide, you will learn how to replace the LG Cosmos motherboard. Take your time when dismantling this device to avoid damaging other components within.
Verify with the LG Cosmos Troubleshooting to see if the motherboard requires replacement. Your Cosmos device may not need this guide it could be a few other issues. One issue could be with the keyboard or another would be with the screen not functioning. Once you have verified that the main problem is the motherboard you can begin the guide.
必要な工具と部品
Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
ある他の人がこのガイドを完成しました。
