この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The motherboard allows all the different parts and functions of the phone to work together.
必要な工具と部品
Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
Push the spudger into the crack separating the two pieces of the phone.
Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
