メインコンテンツにスキップ
LG CF360 LCD Screen Replacement
必要な工具と部品
  1. LG CF360 LCD Screen Replacement, Battery: 手順 1、 2の画像 1 LG CF360 LCD Screen Replacement, Battery: 手順 1、 2の画像 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 LCD Screen Replacement: 手順 2、 1の画像 1
    • Lift and remove the battery.
  3. LG CF360 LCD Screen Replacement, Back Cover: 手順 3、 2の画像 1 LG CF360 LCD Screen Replacement, Back Cover: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 LCD Screen Replacement: 手順 4、 1の画像 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 LCD Screen Replacement: 手順 5、 3の画像 1 LG CF360 LCD Screen Replacement: 手順 5、 3の画像 2 LG CF360 LCD Screen Replacement: 手順 5、 3の画像 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 LCD Screen Replacement: 手順 6、 1の画像 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 LCD Screen Replacement, Motherboard: 手順 7、 2の画像 1 LG CF360 LCD Screen Replacement, Motherboard: 手順 7、 2の画像 2
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
  8. LG CF360 LCD Screen Replacement: 手順 8、 1の画像 1
    • Gently remove the blue transparent tape from the connector.
  9. LG CF360 LCD Screen Replacement: 手順 9、 1の画像 1
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
  10. LG CF360 LCD Screen Replacement, Front Case: 手順 10、 1の画像 1
    • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
  11. LG CF360 LCD Screen Replacement: 手順 11、 1の画像 1
    • Gently pull the orange ribbon from the number pad casing.
    • Set the number pad case to the side once it is detached from the ribbon.
  12. LG CF360 LCD Screen Replacement: 手順 12、 1の画像 1
    この手順で使用する道具:
    • Remove the two red sticker screw coverings at the top corners with tweezers.
  13. LG CF360 LCD Screen Replacement: 手順 13、 1の画像 1
    • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
  14. LG CF360 LCD Screen Replacement: 手順 14、 2の画像 1 LG CF360 LCD Screen Replacement: 手順 14、 2の画像 2
    • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
    • Set the red sliding backing and front cover to the side.
  15. LG CF360 LCD Screen Replacement, LCD Screen: 手順 15、 1の画像 1
    • Be very careful to not damage the green keypad board when using the plastic opening tool.
    • Use a plastic opening tool to carefully disconnect the silver L-shaped LCD screen ribbon.
  16. LG CF360 LCD Screen Replacement: 手順 16、 2の画像 1 LG CF360 LCD Screen Replacement: 手順 16、 2の画像 2
    この手順で使用する道具:
    • At this point, an orange ribbon is still connected to the white and black Zero Insertion Force (ZIF) connector on the keypad board. Be careful to not damage the ribbon.
    • Use tweezers to carefully pry up the black retainer on the connector.
  17. LG CF360 LCD Screen Replacement: 手順 17、 2の画像 1 LG CF360 LCD Screen Replacement: 手順 17、 2の画像 2
    • Lift the keypad board away from the phone casing using a plastic opening tool.
    • Slowly rotate the keypad board towards you to disconnect the second orange LCD screen ribbon and remove the board.
  18. LG CF360 LCD Screen Replacement: 手順 18、 1の画像 1
    • If you have never soldered before, or need a refresher, take a look at iFixit's soldering guide before starting this step.
    • Use a soldering iron and a solder wick to de-solder the 4 wires connected to the LCD screen.
    • The LCD screen can easily be removed at this point by lifting it from the phone casing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ricky Wai
メンバー登録日: 10/15/13
299 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-27, Amido Fall 2013 Cal Poly, Team 4-27, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S4G27
4 メンバー
19のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 1,433
