メインコンテンツにスキップ
Kyocera Hydro Life Charging Port Replacement
必要な工具と部品
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: 手順 1、 2の画像 1 Kyocera Hydro Life Charging Port Replacement, Charging Port: 手順 1、 2の画像 2
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: 手順 2、 3の画像 1 Kyocera Hydro Life Charging Port Replacement: 手順 2、 3の画像 2 Kyocera Hydro Life Charging Port Replacement: 手順 2、 3の画像 3
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: 手順 3、 1の画像 1
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: 手順 4、 3の画像 1 Kyocera Hydro Life Charging Port Replacement: 手順 4、 3の画像 2 Kyocera Hydro Life Charging Port Replacement: 手順 4、 3の画像 3
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: 手順 5、 3の画像 1 Kyocera Hydro Life Charging Port Replacement: 手順 5、 3の画像 2 Kyocera Hydro Life Charging Port Replacement: 手順 5、 3の画像 3
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: 手順 6、 2の画像 1 Kyocera Hydro Life Charging Port Replacement: 手順 6、 2の画像 2
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: 手順 7、 1の画像 1
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: 手順 8、 1の画像 1
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: 手順 9、 1の画像 1
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: 手順 10、 1の画像 1
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
終わりに
作成者
1人の作成者と共同作成されました。
Rebecca Lamb
メンバー登録日: 09/21/18
327 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S2-G6, Riccardelli Fall 2018 University of North Texas, Team S2-G6, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S2G6
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 983
