メインコンテンツにスキップ
Kurio Touch 4S Screen Replacement
必要な工具と部品
  1. Kurio Touch 4S Screen Replacement, Screen: 手順 1、 1の画像 1
    • Make sure to open the back cover easily using the plastic opening tool
  2. Kurio Touch 4S Screen Replacement: 手順 2、 3の画像 1 Kurio Touch 4S Screen Replacement: 手順 2、 3の画像 2 Kurio Touch 4S Screen Replacement: 手順 2、 3の画像 3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Screen Replacement: 手順 3、 2の画像 1 Kurio Touch 4S Screen Replacement: 手順 3、 2の画像 2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Philips#1 Screwdriver.
  4. Kurio Touch 4S Screen Replacement: 手順 4、 1の画像 1
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you get them out of order.
  5. Kurio Touch 4S Screen Replacement: 手順 5、 1の画像 1
    • Remove the plastic cover that is covering the camera area.
  6. Kurio Touch 4S Screen Replacement: 手順 6、 1の画像 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Screen Replacement: 手順 7、 1の画像 1
    • Use Phillips # 1 screw to open the 4 screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Screen Replacement: 手順 8、 1の画像 1
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Screen Replacement: 手順 9、 1の画像 1
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Screen Replacement: 手順 10、 2の画像 1 Kurio Touch 4S Screen Replacement: 手順 10、 2の画像 2
    • Detach all the wire that are connected to the motherboard.
    • Also remove the camera module and other components that are attached to the motherboard.
    • For more information on soldering Click here
  11. Kurio Touch 4S Screen Replacement: 手順 11、 1の画像 1
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Screen Replacement: 手順 12、 1の画像 1
    • Use the Plastic opener to remove the screen.
    • Do not apply too much pressure as the front cover could be damaged.
  13. Kurio Touch 4S Screen Replacement: 手順 13、 1の画像 1
    • Use the soldering tool to remove the wire that is attached to the screen & the motherboard.
  14. Kurio Touch 4S Screen Replacement: 手順 14、 1の画像 1
    • Use tweezers to remove the screen from your Kurio Toich 4S.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ali
メンバー登録日: 01/21/15
184 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015人のメンバー
USFT-BROWN-W15S6G5
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 7
今までの合計 1,376
