メインコンテンツにスキップ
Kurio 7 Battery Replacement
必要な工具と部品
  1. Kurio 7 Battery Replacement, Back Panel: 手順 1、 3の画像 1 Kurio 7 Battery Replacement, Back Panel: 手順 1、 3の画像 2 Kurio 7 Battery Replacement, Back Panel: 手順 1、 3の画像 3
    • Begin by removing the rubber cover from the Kurio 7.
  2. Kurio 7 Battery Replacement: 手順 2、 2の画像 1 Kurio 7 Battery Replacement: 手順 2、 2の画像 2
    • Remove the four 30 mm Phillips #00 screws from the outer case.
  3. Kurio 7 Battery Replacement: 手順 3、 2の画像 1 Kurio 7 Battery Replacement: 手順 3、 2の画像 2
    • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
    • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Be careful not to break off the tabs that hold the front cover and the back cover together.
  4. Kurio 7 Battery Replacement: 手順 4、 2の画像 1 Kurio 7 Battery Replacement: 手順 4、 2の画像 2
    • Once all of the tabs are removed, the back cover should come off easily.
    • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
  5. Kurio 7 Battery Replacement, Battery: 手順 5、 1の画像 1
    • Use a credit card, or other thin object, to separate the battery from the screen.
    • Be sure to work the card slowly and carefully in order to not damage, break, or deform the battery.
  6. Kurio 7 Battery Replacement: 手順 6、 1の画像 1
    • Desolder, or separate using the desoldering braid, the marked areas on the motherboard to remove the old battery.
    • Refer to our soldering guide on how to solder and desolder.
終わりに
Solder in the new battery. To reassemble your device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Alex Powaser
メンバー登録日: 04/14/14
331 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 12-36, Maness Spring 2014 Cal Poly, Team 12-36, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S12G36
4 メンバー
14のガイドは作成済み
コメント 1 件
Can the charging port be replaced in the kurio 7s tablet
Pamela Haughton - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 16,814
