メインコンテンツにスキップ
Konica Minolta Dimage Z6 LCD Screen Replacement
必要な工具と部品
  1. Konica Minolta Dimage Z6 LCD Screen Replacement, LCD Screen: 手順 1、 2の画像 1 Konica Minolta Dimage Z6 LCD Screen Replacement, LCD Screen: 手順 1、 2の画像 2
    • Push the battery cover in and away from the camera.
    • Remove all four batteries.
    • Close the battery cover before continuing.
  2. Konica Minolta Dimage Z6 LCD Screen Replacement: 手順 2、 3の画像 1 Konica Minolta Dimage Z6 LCD Screen Replacement: 手順 2、 3の画像 2 Konica Minolta Dimage Z6 LCD Screen Replacement: 手順 2、 3の画像 3
    • Use a Phillips #000 screwdriver to remove the two black screws above the LCD screen.
    • The screws are small and fall out easily. You should take them out over a solid surface and set them aside somewhere safe.
    • Remove the black view protector.
    • Remove the screen cover by applying slight force at the top, then pulling away from the camera.
  3. Konica Minolta Dimage Z6 LCD Screen Replacement: 手順 3、 3の画像 1 Konica Minolta Dimage Z6 LCD Screen Replacement: 手順 3、 3の画像 2 Konica Minolta Dimage Z6 LCD Screen Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    購入する
    • Carefully use the spudger to pop the LCD screen out of the bracket.
    • The LCD screen should still be attached by orange ribbon cable and two wires, one orange and one white.
    • Use tweezers to carefully pull the ribbon cable from the logic board, not from the LCD screen.
    • Peel back yellow tape on LCD screen to reveal where the two wires are attached. Use tweezers to detach the orange and white wires from the LCD screen.
    • Attach the wires to the new screen in the same spot they were attached to the old one.
    • Attach the new screen's ribbon tape to the logic board underneath the metal plate.
    • With the new screen attached, put it in place on the metal plate. You can now replace the screen cover.
  4. Konica Minolta Dimage Z6 LCD Screen Replacement: 手順 5、 1の画像 1
    • As you start to reassemble, note the grey extension at the bottom of the black screen cover. Apply pressure to the bottom of the cover and slide upwards onto screen.
終わりに
With the main screen cover in place, follow steps 1-3 in reverse to completely reassemble the device. If the new screen was attached correctly, the camera should function as normal.
作成者
9人の作成者と共同で作成されました。
Ethan Anderson
メンバー登録日: 02/16/16
1 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-3, Burgess Spring 2016 Ohio State, Team 1-3, Burgess Spring 2016人のメンバー
OSU-BURGESS-S16S1G3
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 17
今までの合計 760
