はじめに
This guide demonstrates how to replace the lens.
ツール
パーツ
パーツは指定されていません。
Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
Remove all 7 screws:
Hold the camera firmly with one hand so that you can still see a screw.
Place the Philips 00(Found here)screwdriver into the screw.
Turn the screwdriver to the left until it is free.
Repeat for the remaining screws.
Use plastic opening tools to slightly open the side of the case.
Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
The first two are near the words "3X Optical Zoom".
The third is near the shutter button.
Open the battery door.
Press thumb firmly on battery door and slide it in the direction of the arrow.
Lift thumb allowing the door to swing open.
The battery door on my easyshare c813 is broken. How can i get a replacement door?
Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
ある他の人がこのガイドを完成しました。
コメント1件
Great, please I need help on my Kodak easyshare z1085 IS, other things is working, but always black can't see anything through the screen
