メインコンテンツにスキップ
Kodak Easyshare C813 LCD Replacement
必要な工具と部品
  1. Kodak Easyshare C813 LCD Replacement, Battery: 手順 1、 1の画像 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Kodak Easyshare C813 LCD Replacement: 手順 2、 3の画像 1 Kodak Easyshare C813 LCD Replacement: 手順 2、 3の画像 2 Kodak Easyshare C813 LCD Replacement: 手順 2、 3の画像 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Kodak Easyshare C813 LCD Replacement, Back Cover: 手順 3、 1の画像 1
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
  4. Kodak Easyshare C813 LCD Replacement: 手順 4、 1の画像 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Kodak Easyshare C813 LCD Replacement: 手順 5、 3の画像 1 Kodak Easyshare C813 LCD Replacement: 手順 5、 3の画像 2 Kodak Easyshare C813 LCD Replacement: 手順 5、 3の画像 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Kodak Easyshare C813 LCD Replacement: 手順 6、 3の画像 1 Kodak Easyshare C813 LCD Replacement: 手順 6、 3の画像 2 Kodak Easyshare C813 LCD Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    Phillips #00 Screwdriver
    $5.49
    購入する
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Kodak Easyshare C813 LCD Replacement: 手順 7、 3の画像 1 Kodak Easyshare C813 LCD Replacement: 手順 7、 3の画像 2 Kodak Easyshare C813 LCD Replacement: 手順 7、 3の画像 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Kodak Easyshare C813 LCD Replacement: 手順 8、 3の画像 1 Kodak Easyshare C813 LCD Replacement: 手順 8、 3の画像 2 Kodak Easyshare C813 LCD Replacement: 手順 8、 3の画像 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Kodak Easyshare C813 LCD Replacement, Front Cover: 手順 9、 2の画像 1 Kodak Easyshare C813 LCD Replacement, Front Cover: 手順 9、 2の画像 2
    • Open the battery door.
    The battery door on my easyshare c813 is broken. How can i get a replacement door?
    paul chadwell - 返信
  10. Kodak Easyshare C813 LCD Replacement: 手順 10、 3の画像 1 Kodak Easyshare C813 LCD Replacement: 手順 10、 3の画像 2 Kodak Easyshare C813 LCD Replacement: 手順 10、 3の画像 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Kodak Easyshare C813 LCD Replacement: 手順 11、 1の画像 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Kodak Easyshare C813 LCD Replacement, LCD: 手順 12、 3の画像 1 Kodak Easyshare C813 LCD Replacement, LCD: 手順 12、 3の画像 2 Kodak Easyshare C813 LCD Replacement, LCD: 手順 12、 3の画像 3
    • Once the front cover is removed, the battery door maybe closed for convenience.
    • Locate the exposed portion of the LCD screen.
    • Use a wedge to free the LCD screen from the medal housing.
    • Do not pull the screen away completely, it is still attached to the logic board via the yellow cable.
  13. Kodak Easyshare C813 LCD Replacement: 手順 13、 1の画像 1
    • Remove the screw at the upper right corner of the metal housing.
  14. Kodak Easyshare C813 LCD Replacement: 手順 14、 3の画像 1 Kodak Easyshare C813 LCD Replacement: 手順 14、 3の画像 2 Kodak Easyshare C813 LCD Replacement: 手順 14、 3の画像 3
    • Locate the 2 solder joints holding down the medal housing.
    • Remove the solder.
    • Place wick on solder.
    • Place solder iron on wick
    • The wick should be sandwiched between the iron and the solder.
  15. Kodak Easyshare C813 LCD Replacement: 手順 15、 3の画像 1 Kodak Easyshare C813 LCD Replacement: 手順 15、 3の画像 2 Kodak Easyshare C813 LCD Replacement: 手順 15、 3の画像 3
    • Peel back the black tape from the metal housing.
    • Lift the metal housing from the left so that it hinges on its right side.
    • The metal housing is still loosely attached on its right side.
  16. Kodak Easyshare C813 LCD Replacement: 手順 16、 3の画像 1 Kodak Easyshare C813 LCD Replacement: 手順 16、 3の画像 2 Kodak Easyshare C813 LCD Replacement: 手順 16、 3の画像 3
    • Locate black tab holding the LCD screen connector in the port.
    • Use wedge or fingernail to lift the black tab.
    • Pull the the LCD screen connector out of the port.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Samantha Murray
メンバー登録日: 04/15/10
269 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S24G22
4 メンバー
20のガイドは作成済み
コメント 1 件
De sluiterknop werkt niet altijd, hoe is dit op te lossen?
Jacobus Rijken - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 31
今までの合計 13,106
