メインコンテンツにスキップ
Kodak EasyShare M1033 LCD Screen Assembly Replacement
必要な工具と部品
  1. Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: 手順 1、 3の画像 1 Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: 手順 1、 3の画像 2 Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: 手順 1、 3の画像 3
    • Ensure that the camera is powered off.
    • Turn the camera over so the battery compartment is facing up.
    • Place your thumb on the embossed surface of the battery latch, and push down and out until the latch releases.
    • Push down on the orange tab to release and remove the batteries.
    • Close the latch.
    • Let the camera sit for a minute to avoid electrical shock.
  2. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 2、 3の画像 1 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 2、 3の画像 2 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 2、 3の画像 3
    • Use a Phillips #00 screwdriver to remove six screws along the edge of the camera.
    • There are two screws next to the battery compartment
    • Two screws on the left side
    • Two screws on the right side
  3. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 3、 3の画像 1 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 3、 3の画像 2 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 3、 3の画像 3
    • Use a spudger or your fingernail to pry the plastic case covering the LCD screen from the back of the camera.
  4. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 4、 3の画像 1 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 4、 3の画像 2 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 4、 3の画像 3
    • Use a spudger to gently pry the LCD assembly and move it to reveal a ZIF connector.
    • Don't pull it off as it is connected by a ribbon cable.
    • Use your fingernail or the tip of the spudger to flip up the small locking flap.
    • Gently pull the cable out.
    • Remove the old LCD screen assembly.
  5. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 5、 3の画像 1 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 5、 3の画像 2 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 5、 3の画像 3
    • Carefully insert the ribbon cable of the new LCD screen assembly into the ZIF connector and securely flip the lock down.
    • Ensure that the ribbon is secure.
    • Place the LCD screen assembly back into the original position.
  6. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 6、 3の画像 1 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 6、 3の画像 2 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 手順 6、 3の画像 3
    • Place the back case on top of the new LCD screen.
    • Use the Phillips #00 screwdriver to replace the six screws along the edge of the camera that secure the back case.
    • Righty tighty.
終わりに
作成者
2人の作成者と共同で作成されました。
ntuong1117
メンバー登録日: 03/05/24
133 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 8-13, Grodsky Spring 2024 CSU Los Angeles, Team 8-13, Grodsky Spring 2024人のメンバー
CSULA-GRODSKY-S24S8G13
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 20
今までの合計 69
