はじめに
If your Kindle Fire HDX 7” tablet is staying bright when the night falls and dark when the suns out, the ambient light sensor may be busted.
First check the settings and make sure that auto brightness is turned on, if it is, follow this guide to replace it yourself.
必要な工具と部品
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
Pry up the ambient light sensor press-fit connector from the motherboard with the flat end of a spudger.
もう少しです!
終わりに
