はじめに
Use this guide to replace the Limit Switch that tells the Keurig that the K-Cup section is closed.
必要な工具と部品
Remove the switch by cuting the two connecting wires. Reconnect a replacement switch using this guide to join wires with solder, or using this guide to solder connections, or by using any other technique to connect wires.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
