はじめに
This guide shows how to remove and replace the gear case assembly for the Karcher Rotary Floor Cleaner 17833080 2017.
This guide can also be used to remove and replace the parts listed in the parts section.
必要な工具と部品
Press the yellow button near each wheel base to release the wheels.
Remove both wheels from their sockets.
Press the yellow foot switch at the base of the device to lower the suction bars.
Tilt the top of the roller brush out of the brush well.
Remove both roller brushes.
Press the yellow button on the suction bar retaining bracket to release the suction bar.
Remove the following screws securing the left retaining bracket:
Four T40 screws
Two T20 screws
Raise the handle to the upright position.
Engage the retaining bracket to lock the handle in place.
Use a T20 driver to remove the two screws securing the right splash guard.
Use a T20 driver to remove the following screws securing the right retaining bracket:
Two 85 mm-long screws
Four 45 mm-long screws
Disconnect the two remaining plugs by squeezing the edges and pulling them out of their sockets.
Vacuum motor
Pump
Handle
Use a T20 driver to remove the six screws securing the plastic brush housing.
Use a T20 driver to remove the two screws securing the socket board.
Squeeze the edges of the drive motor plug and disconnect it from the extension plug.
Use a T20 driver to remove the six bolts securing the gear case cover.
Remove the following bolts from the gear case:
Six T20 bolts
One T30 bolt securing the ground wire
Lift the motor end of the drive assembly up slightly to clear the mounting lip.
Push the drive assembly out of its recess.
Use snap ring pliers to remove the retaining ring securing the motor axle.
The motor axle is keyed into the gearbox. Rotate the axle until it aligns with the gearbox slot.
Align the gear case to the motor mount using the two alignment pins.
Once everything is aligned, gently tap the gear case onto the motor mount.
