メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Jazz Ultratab C954 Speaker Replacement
必要な工具と部品
  1. Jazz Ultratab C954 Speaker Replacement, Back Cover: 手順 1、 2の画像 1 Jazz Ultratab C954 Speaker Replacement, Back Cover: 手順 1、 2の画像 2
    • On the top of the tablet there are two 1cm screws that hold the back cover on. Locate these screws and remove them using a Phillips head #0 screw driver.
    FixBotに聞いてみる
    コメントを追加
  2. Jazz Ultratab C954 Speaker Replacement: 手順 2、 1の画像 1
    • You now have to pry the back cover from the touch screen panel. To do this insert a plastic spudger into the seem. Then work your way around the panel until it is free.
    • There are buttons on the top side of the tablet that go through the back cover. The cover must slide up when removed to avoid damaging the buttons.
    FixBotに聞いてみる
    コメントを追加
  3. Jazz Ultratab C954 Speaker Replacement: 手順 3、 1の画像 1
    • This is what your tablet should look like once the back cover is removed. You are now ready to begin repairing your tablet. Follow the corresponding guide for instructions on repairing major components.
    • To reattach the back cover begin by sliding the cover on making sure the buttons and the speaker are in their designated holes on the back cover. Then attach the two covers by pressing them together until you hear the plastic tabs interlock.
    • With the two screens held together the last step is to put the two 1cm screws on the top of the tablet back in. Your tablet is now ready for use again!
    FixBotに聞いてみる
    コメントを追加
  4. Jazz Ultratab C954 Speaker Replacement, Speaker: 手順 4、 1の画像 1
    • With the back cover removed from your tablet locate the speaker and the speaker wires shown in the red box.
    FixBotに聞いてみる
    コメントを追加
  5. Jazz Ultratab C954 Speaker Replacement: 手順 5、 1の画像 1
    • Since the speaker is magnetically held to the screen of the tablet cutting the old wires will remove the old speaker.
    • Use caution when cutting the wires, you want to cut the wires as close to the motherboard as possible without harming the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Jazz Ultratab C954 Speaker Replacement: 手順 6、 2の画像 1 Jazz Ultratab C954 Speaker Replacement: 手順 6、 2の画像 2
    • Locate the positive and negative terminals of the speaker.
    • To attach the new speaker you must solder the new wires to the terminals on the motherboard. To do this hold the wire on the old solder, using a small amount of solder melt the solder and wires to the old connection points.
    • Soldering irons are very hot and can cause serious injury. If you do not know how to use a soldering iron please seek help from someone who is experienced.
    • For an explanation on soldering refer to iFixit's soldering guide はんだ付けとはんだ除去の作業ガイド
    FixBotに聞いてみる
    コメントを追加
  7. Jazz Ultratab C954 Speaker Replacement: 手順 7、 1の画像 1
    • Your new speaker is now fully attached to the tablet ans should be operational. You can now reassemble the tablet. To do so refer to the back cover guide (step 3).
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Nicole Nault
メンバー登録日: 03/25/15
413 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-7, Shastany Spring 2015 UMass Dartmouth, Team 1-7, Shastany Spring 2015人のメンバー
UMASSD-SHASTANY-S15S1G7
3 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 31
今までの合計 440
