はじめに
The two speakers in the Jawbone MINI JAMBOX are what provide the sound. Excessive use of the speakers can lead to them becoming damaged, and the device becoming unusable.
必要な工具と部品
Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
Remove all connecting ribbons from the motherboard.
One ZIF or "zero insertion force" ribbon connecting at the side.
One standard ribbon connector in the middle (Note: this ZIF ribbon is lightly glued to the surface).
In order to remove the speakers, you must rotate them. Rotate the circled tabs away from their adjacent tabs.
Once the speakers are completely rotated, you should see new tabs rotate into sight (see the orange marks).
5 の人々がこのガイドを完成させました。
3 件のコメント
where can i buy replacement speakers
Thank you for the instructions. I was wondering where to start.
