メインコンテンツにスキップ
Jawbone MINI JAMBOX Motherboard Replacement
必要な工具と部品
  1. Jawbone MINI JAMBOX Motherboard Replacement, Outer Case: 手順 1、 2の画像 1 Jawbone MINI JAMBOX Motherboard Replacement, Outer Case: 手順 1、 2の画像 2
    • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
  2. Jawbone MINI JAMBOX Motherboard Replacement: 手順 2、 1の画像 1
    • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
    • Carefully remove the end panel.
    • The tabs which connect the panel are on the short sides.
    • WARNING: you will likely cause cosmetic damage to the end cap.
  3. Jawbone MINI JAMBOX Motherboard Replacement: 手順 3、 1の画像 1
    • Slide out the rubber foot located on the bottom of the case.
  4. Jawbone MINI JAMBOX Motherboard Replacement: 手順 4、 1の画像 1
    • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
    • This is the only flat topped screw in the speaker, so keep track of which one it is.
  5. Jawbone MINI JAMBOX Motherboard Replacement: 手順 5、 3の画像 1 Jawbone MINI JAMBOX Motherboard Replacement: 手順 5、 3の画像 2 Jawbone MINI JAMBOX Motherboard Replacement: 手順 5、 3の画像 3
    • Push against the side without end cap to slide the internal components out of the case.
    • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
    • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
  6. Jawbone MINI JAMBOX Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Remove all connecting ribbons from the motherboard.
    • One ZIF or "zero insertion force" ribbon connecting at the side.
    • One standard ribbon connector in the middle (Note: this ZIF ribbon is lightly glued to the surface).
  7. Jawbone MINI JAMBOX Motherboard Replacement: 手順 7、 1の画像 1
    • Unscrew all four 5mm T6 screws holding the motherboard to the plastic case.
    • Unlike the flat top screw holding the metal housing, these screws are roundtop.
  8. Jawbone MINI JAMBOX Motherboard Replacement: 手順 8、 1の画像 1
    • Desolder the grounding plug from the motherboard.
    • Make sure your soldering iron is tinned and carefully touch the tip of your iron to the grounding lug. Allow the the solder to liquify. While liquified, lift the motherboard off the grounding lug.
    • WARNING: Do not allow the solder to spill over and bridge any connection on the motherboard.
    • New to soldering? Look at iFixit's soldering guide here.
  9. Jawbone MINI JAMBOX Motherboard Replacement: 手順 9、 1の画像 1
    • Carefully lift the motherboard out of the plastic housing.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Liam McDonnell
メンバー登録日: 04/01/15
559 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S12G1
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,313
